It is currently Thu Aug 13, 2026 8:29 pm
 Post subject: How to create a double exposure effect_ 2 Tutorials (update)
PostPosted: Fri Jan 26, 2018 5:51 am  (#1)
I hope this tutorial can be helpful to create this effect named "Double Exposure". :)
Here you have a new technique to get this effect, maybe you find it more artistic.
(see samples and results) at the end of the thread.
Enjoy them. :bigthup
Tutorial New technique to get An Artistic Double Exposure Effect.pdf [606.17 KiB]
Downloaded 684 times
How to create a double exposure effect- Tutorial.pdf [616.35 KiB]
Downloaded 813 times
 Post subject: Re: How to create a double exposure effect_ Tutorial
PostPosted: Sat Jan 27, 2018 7:02 am  (#2)
issabella: Thank you for sharing this - I've been curious to see the work process you use.
PostPosted: Sat Jan 27, 2018 8:17 am  (#3)
Me too. I love the effect and it will be interesting to see your techniques Issabella. :)
PostPosted: Sat Jan 27, 2018 2:52 pm  (#4)
May i suggest that you guys do a google image search for Double Exposure ?!
What you will discover is that most of the image examples clip the double exposure to a shape (often the head and face of somebody), which, in my opinion, makes for a stronger effect.
https://img00.deviantart.net/a882/i/201 ... 7u4zl4.jpg
https://img00.deviantart.net/604a/i/201 ... 8ud5gd.jpg
https://pre00.deviantart.net/fbdd/th/pr ... 9ubnn8.jpg
https://orig00.deviantart.net/0db8/f/20 ... 91sjwq.jpg
PostPosted: Sun Jan 28, 2018 3:27 am  (#5)
Just looked at your tutorial properly Issabella. I think you have explained your process really well and balanced the amount of text to illustrations perfectly. Great job.
PostPosted: Sun Jan 28, 2018 7:05 am  (#6)
Thank you so much Erisian, AnMal and Skinnyhouse. I'm glad this tut can be helpful. :tyspin
you are right Konstantin. :)
I'm preparing a new tut about a new method to get this effect. I'll post it today :)
 Post subject: Re: How to create a double exposure effect_ 2 Tutorials (update)
PostPosted: Sun Jan 28, 2018 8:51 am  (#7)
some results with second tutorial.
PostPosted: Sun Jan 28, 2018 8:52 am  (#8)
