It is currently Thu Oct 08, 2026 11:28 pm
 Post subject: sepia look
PostPosted: Mon Oct 01, 2018 10:40 pm  (#1)
Greetings to all,
Can someone point me to how to turn an image to sepia? (I am using gimp 2.6 or 2.7 in windows).
Thanks in advance
 Post subject: Re: sepia look
PostPosted: Mon Oct 01, 2018 10:55 pm  (#2)
You're using a pretty old version of GIMP, Ed. That said the tutorial below will work. :)
https://www.gimp.org/tutorials/Sepia_Toning/
PostPosted: Mon Oct 01, 2018 10:58 pm  (#3)
I have used this tutorial and it is good. You can of course also use it as a basis to start from.
:ninja almost Lyle
PostPosted: Tue Oct 09, 2018 6:41 pm  (#4)
I got stucked in step 3.
PostPosted: Tue Oct 09, 2018 9:20 pm  (#5)
The "Sepia"color used in the tutorial is HTML Notation a28a65 .
Click on the Black Foreground Swatch.
To open the Change Foreground Color Dialog.
Enter the HTML Notation of a28a65,
into the provided space,
within the Color Selection Dialog.
PostPosted: Wed Oct 10, 2018 4:13 am  (#6)
You should seriously consider switching to newer version of Gimp.
FX Foundry script package (last built is for 2.6, works also in 2.8) includes a script with multiple sepia and other duotone presets.
It's the "egger-duotone-simulation.scm"
I see there's also
"Klawiter-sepia-toning.scm" &
"cprogrammer-midnight-sepia.scm"
http://gimpfx-foundry.sourceforge.net/
PostPosted: Mon Oct 15, 2018 1:43 pm  (#7)
Thanks, I will give it a try.
PostPosted: Mon Oct 15, 2018 1:46 pm  (#8)
I see there's also
I know, the thing is that the machine at the office is not available right now (not the w10 one) so I have had to use the older one with gimp 2.6.
I am going to take a look at the scipt, thank you for the information.
