It is currently Fri Oct 09, 2026 1:42 am
 Post subject: How to warp only a section of a photo?
PostPosted: Tue Dec 25, 2018 10:56 am  (#1)
In the old GIMP I could box select a person then IWarp them without affecting the people on either side.
In GIMP 2.1 how do I use the Warp Transform tool to distort a person and their immediate surrounding background without the warping affecting further parts of the image, like people on either side?
 Post subject: Re: How to warp only a section of a photo?
PostPosted: Tue Dec 25, 2018 12:28 pm  (#2)
You can use the Cage Transform tool for that. It is in the standard toolbox, thepicto with the multiple selection points connected with lines.
PostPosted: Tue Dec 25, 2018 12:32 pm  (#3)
I can't remember if the cage transform pulls in the rest of the image too, but either way, it leaves behind a weird ghost outline of the object you're distorting, unlike the warp tool.
PostPosted: Tue Dec 25, 2018 12:40 pm  (#4)
I didn't notice that last time I used it and you can definitely use it only on part of the image.
