It is currently Wed Oct 07, 2026 11:35 am
 Post subject: Zoobka: technique to get nice effects of light and matter
PostPosted: Sun Jan 19, 2020 5:29 am  (#1)
Zoobka is a technique to easily create abstracts with cool effects of light and matter.
The tutorial with samples of what can be done with it:
https://www.gimp-forum.net/Thread-Zoobk ... al-effects
And the gallery thread where you can post your own creations:
viewtopic.php?f=11&t=17944
If you have any question, remark, suggestion... you can post it here.
Some "zoobkas":
 Post subject: Re: Zoobka: technique to get nice effects of light and matter
PostPosted: Sun Jan 19, 2020 5:32 am  (#2)
Do you know Zoobka? viewtopic.php?f=10&t=17945
I'm on DA: https://www.deviantart.com/g017/gallery
Flickr: https://www.flickr.com/people/g017
PostPosted: Sun Jan 19, 2020 12:47 pm  (#3)
Thank You g017.
:jumpclap
For sharing this tutorial with us.
It has been added to our Gimp Chat Tutorial Index ,
for future reference.
PostPosted: Mon Jan 20, 2020 6:24 pm  (#4)
Thank You g017.
:jumpclap
Great! You are welcome and thanks to you too. ;)
PostPosted: Mon Jan 20, 2020 6:26 pm  (#5)
g017 wrote:
Great!
PostPosted: Tue Jun 28, 2022 1:08 am  (#6)
In the Tutorial Step 3 Says
3. Apply colors. Personally I use the G'Mic filter "Plasma" set on the "Vivid light" merging mode.
I Cannot find this Filter I Found Plasma Filer but It does Not have the the "Vivid light" merging mode Selection
PostPosted: Tue Jun 28, 2022 1:56 am  (#7)
'Vivid Light' is a layer mode not a filter.
After applying plasma on a new layer you need to go back to gimp and use the layer mode there
PostPosted: Tue Jun 28, 2022 7:50 pm  (#8)
I followed the instructions I think, but mine doesn't look as good as the examples... sigh.
