It is currently Fri Oct 09, 2026 11:27 pm
 Post subject: Create Layer Mask From
PostPosted: Thu Nov 05, 2020 4:38 pm  (#1)
Okay, so I download this plugin called Create Layer Masks From and I'm not sure how to use it. I've looked everywhere I can think of for a tutorial on it and I've come up empty. The plugin can be found here: https://www.deviantart.com/slybug/art/C ... -324277895
Is it possible for a tutorial to be created on how to use this plugin?
 Post subject: Re: Create Layer Mask From
PostPosted: Fri Nov 06, 2020 12:04 am  (#2)
Two personal comments:
1-downloaded it, installed, tried: got an error because Gimp (at least my version 2.10.23) does not accept to create a layer mask taking it from a mask which is attached to another image
2-the function it wants to perform is doable using standard Gimp functions on mask
PostPosted: Fri Nov 06, 2020 3:41 am  (#3)
It just does what it says on the deviantart page
This plugin allows you to create layer mask from another layer mask.
Or create layer mask from grayscale copy of layer.
Unzip put create-layer-mask-from.py in C:\Users\"yourname"\AppData\Roaming\GIMP\2.10\plug-ins
Do not bother with the locale folder unless you use Russian language.
Find the plug right-click in layer dialogue, near the bottom.
Saves a copy and paste, very similar to the older Saul Goode script but with more options.
From a black / white layer: example: https://i.imgur.com/l0ISIP0.mp4
From a layer with an existing layer mask: example: https://i.imgur.com/yEbAIQ4.mp4
PostPosted: Fri Nov 06, 2020 4:56 am  (#4)
I see (everything inside tha same image).
IMHO it's practically useless, given the std Gimp functions (which BTW allow the user also to "copy" a layer mask from a layer attached to another image, which is what I was supposing the filter did)
PostPosted: Fri Nov 06, 2020 5:15 am  (#5)
Yes, but that was not the original question, which was
...I'm not sure how to use it.
PostPosted: Fri Nov 06, 2020 12:45 pm  (#6)
No, my original question was: Is it possible for a tutorial to be created on how to use this plugin?
PostPosted: Fri Nov 06, 2020 12:47 pm  (#7)
I have it set up in gimp, but I don't know how to use it.
PostPosted: Fri Nov 06, 2020 1:40 pm  (#8)
I am sure a tutorial could be created but if you can not figure it out from:
then there is no hope
PostPosted: Fri Nov 06, 2020 1:49 pm  (#9)
Rich2005, I'm a visual learner. I learn by seeing how things are done and that's why I asked about a tutorial. There is always hope. :)
