It is currently Mon Nov 16, 2026 10:08 am
 Post subject: 4 Roses (or anything else) Plaid Tutorial
PostPosted: Tue Sep 23, 2025 11:47 am  (#1)
Hello everyone,
I had a lot of fun making plaid the involves 4 different images.
To me it's a form of art. I feels fun. There's some hand drawn aspect, some automation and some image selection.
Ok here goes.
Things you'll need:
4 different images (same size).
The "Select Diagonals" plug-in viewtopic.php?f=9&t=21324
Since we'll be make a plaid it's a good idea to select 2 bright images and 2 dark images (they don't have to be but I think it makes the plaid result look better).
1. Take a (dark) image (in this case I am doing roses) and put it on the bottom
2. Take a light image put it on top and erase or mask out (using hand drawn brush to add hand drawn features) some alternating vertical hand drawn features (like shown).
3. Merge the masked out image in step 2 with image in step 1.
4. Do step 1 to step 3 for the remaining dark and light image (except instead of vertical hand drawn masking, do horizontal hand drawn masking)
4a.(dark image)
4b. (mask light image horizontally)
4c. (merge the horizontally masked with 4a step image)
5. Use "Select Diagonal" plug-in to select diagonals from step 3 result and delete it so that only alternating diagonals are showing, You might have to add alpha channel to your result before deleting erasing diagonals so that they're transparent.
6. Put step 5 result above step 4 result. Done. Congratulations.
 Post subject: Re: 4 Roses (or anything else) Plaid Tutorial
PostPosted: Tue Sep 23, 2025 11:48 am  (#2)
result of this tutorial is shared in GIMP Art here under 4 roses plaid: viewtopic.php?f=11&t=21887
PostPosted: Tue Sep 23, 2025 12:16 pm  (#3)
Downtown plaid made from 4 different images of downtown from unsplash.com
PostPosted: Wed Sep 24, 2025 10:50 am  (#4)
Video tutorial in GIMP 2.10: https://www.youtube.com/watch?v=rmwp2nPKOkI
PostPosted: Wed Sep 24, 2025 12:29 pm  (#5)
I thought maybe 4 image is too much.
I like 2 image plaid better
here's a 2 image plaid.
technique is the same i used the same 2 images for horizontal weave and vertical weave.
