It is currently Tue Nov 24, 2026 4:25 am
 Post subject: Path Helper
PostPosted: Fri Oct 17, 2025 9:25 am  (#1)
I really enjoy working with paths - perhaps it is because my drawing skills are so limited.
Some people find it difficult to get started with paths so this collection, in pdf format, of tips and bits and pieces of information may be of some use.
Path_Info.pdf [948.88 KiB]
Downloaded 406 times
Added some help for scaling paths:
Scaling-Example.pdf [977.92 KiB]
Downloaded 302 times
I started it so long ago that I cannot remember where some of the resources came from - possibly Ofnuts or Tim or even from the official Gimp site; I am extremely grateful to whoever made them available.
A little doodle - made with 2 paths each with four points.
 Post subject: Re: Path Helper
PostPosted: Fri Oct 17, 2025 11:40 am  (#2)
Thank you so much Skinnyhouse. A great tutorial and it is really helpful. :clap :tyspin
PostPosted: Fri Oct 17, 2025 12:56 pm  (#3)
:coolthup Thank you Master :coolthup
PostPosted: Fri Oct 17, 2025 1:43 pm  (#4)
Thanks for sharing this with us Skinnyhouse!
:jumpclap :clap :jumpclap
It's good to see paths getting the attention they deserve,
your doodle is a perfect example of how creative they can be.
The PDF looks like a really handy resource too!
Added to our tutorial index.
PostPosted: Fri Oct 17, 2025 3:03 pm  (#5)
Thank you Skinnyhouse. :coolthup
PostPosted: Sat Oct 18, 2025 1:38 am  (#6)
Thanks a lot Skinnyhouse.
PostPosted: Sat Oct 18, 2025 12:49 pm  (#7)
Nicely done, Skinnyhouse. Thanks for your help.
Charles
PostPosted: Sun Oct 19, 2025 2:36 am  (#8)
Thanks for all the positive feedback :bigthup - thought it could be a case of teaching grandmother to suck eggs but if it helps, it helps (as they say).
Just to conclude here is a more complex image that began with the text of course (or at least a version of the text).
Everything was created from a path - the download contains the xcf file with all the paths and layers so you can see how I set about it.
UphillStruggle.7z [2.88 MiB]
Downloaded 276 times
PostPosted: Mon Oct 20, 2025 10:48 am  (#9)
Thanks for the tutorial, skinnyhouse.
It's a great help :tyspin
PostPosted: Tue Nov 04, 2025 8:15 am  (#10)
Thank you Ella. I have added some help for scaling paths to the first post that you may find useful.
PostPosted: Wed Nov 05, 2025 4:08 am  (#11)
Nice tutorials Skinnyhouse :tyspin
PostPosted: Thu Nov 06, 2025 4:39 am  (#12)
Thanks again, Skinnyhouse :yr
PostPosted: Thu Nov 06, 2025 10:05 am  (#13)
Thank you so much, Skinnyhouse. :yr
