It is currently Sat Nov 21, 2026 5:14 pm
 Post subject: Platinum Imperial Purple FX
PostPosted: Mon Feb 02, 2026 9:22 pm  (#1)
Platinum Imperial Purple FX, With Gimp 3
Zip file also has the example image to work with!
Platinum Imperial Purple FX.zip [1.23 MiB]
Downloaded 236 times
Intel(R) Core(TM) Ultra 7
 Post subject: Re: Platinum Imperial Purple FX
PostPosted: Tue Feb 03, 2026 2:58 pm  (#2)
I like the outcomes with your platinum effects. Thank you so much for your excellent tutorials. :tyspin
PostPosted: Tue Feb 03, 2026 10:02 pm  (#3)
The Wide Bottom border is set to actual poster standards,
based on the area around your image to create the proper display.
PostPosted: Sun Feb 08, 2026 1:59 pm  (#4)
Thank you so much.
PostPosted: Sun Feb 08, 2026 9:27 pm  (#5)
Nice Image!
