It is currently Mon Nov 16, 2026 9:49 am
 Post subject: Using the Desaturate option in Custom Font Bevel Reflect (Gimp 2.10)
PostPosted: Tue Jun 09, 2026 4:43 am  (#1)
Quick one following on from a custom font BRL chat with Rod...
Sometimes I create what I feel is a brilliant Emap image for use with BRL custom fonts only to find that the results are rather underwhelming to say the least.
Take this Emap which I have had for such a long time that I no longer can remember where the source image came from.
I was convinced that the result would be spectacular…
...but oh dear me:
A truly disappointing outcome when applied to a custom font using Custom Font Bevel Reflect!
Time for a re-think.
The new plan:
Use Custom Font FaceMaker to apply the same image to a set of custom font characters and then apply the highlights generated by the same Emap by using the desaturate emap result option.
So starting with a trimmed version of a custom font using Custom Font Embossible to apply a base gloss effect.
Add the image to the gloss panel characters with the FaceMaker plug-in.
The new characters still need a touch of BRL highlighting to add some extra detail.
Using a different Emap that I originally saved as iceball with the BRL custom font plug-in:
Setting the ‘Desaturate emap result’ option to ‘Desaturate Average’ (other options are available):
Different emaps obviously produce different highlights when used with the same character layers.
My final look after adding a box outline with Custom Font Embossible…
Although I could easily have produced a 3D version instead using Custom Font Faux 3D…
An overview of the steps involved...
Have fun...
 Post subject: Re: Using the Desaturate option in Custom Font Bevel Reflect (Gimp 2.1
PostPosted: Tue Jun 09, 2026 8:50 am  (#2)
Cool. Be nice to have that script for gimp vs 3 (BRL)
They are nice Skinny :)
PostPosted: Tue Jun 09, 2026 1:05 pm  (#3)
The trouble is that BRL depends on a C-plug-in (MLBevelReflect).
So someone who can do C-programming and compiling would be needed.
Only then it would make sense to adapt BRL to GIMP3
PostPosted: Tue Jun 09, 2026 2:19 pm  (#4)
Absolutely QR.
And of course my custom font plug-in only makes use of the MLBevelReflect plug-in.
So yet another reason to use 2.10.
:bawl
PostPosted: Sat Jun 13, 2026 3:22 pm  (#5)
Those results look great Skinnyhouse! :)
