It is currently Mon Nov 16, 2026 10:20 am
 Post subject: How to create a great Filter Sketch - G'MIC-QT
PostPosted: Fri Sep 11, 2026 5:59 pm  (#1)
Study in creating a great Filter Sketch!
In this study I will show you how to fix some of those problem,
in a simple and easy way. Plus, we’ll add some G’MIC-QT effects to make that filter
sketch of your standout over the others. Even thou this isn’t perfect; it will give you
a very good starting place for creating some great art work.
Filter Sketch G'MIC-QT.zip [2.22 MiB]
Downloaded 682 times
Intel(R) Core(TM) Ultra 7
 Post subject: Re: How to create a great Filter Sketch - G'MIC-QT
PostPosted: Fri Sep 11, 2026 6:34 pm  (#2)
About the example shown here, in my filter sketch I used a Curve Adjustment
layer to move and adjust the darkest or black areas in my filter sketch. What it does is give you
a little more details by changing how much black is being shown. The Curves setting shown
here is another option you can use in the tutorial for step 10 (a).
PostPosted: Fri Sep 11, 2026 6:44 pm  (#3)
This is an example of what you can create with this Filter Sketch Tutorial.
Again this is just an example and not the golden rule. But a good place to start with.
PostPosted: Fri Sep 11, 2026 8:24 pm  (#4)
This image has the Filter Sketch as a base and then a cross-hatch sketch
above it. Blended together only using blending modes, and opacity adjustments.
Because of the black jacket reflection, and the face and hands are very light and faint
in details. Otherwise, it wouldn't work with only sketch ideal. Hope this helps.
This frame is for a 6" x 9" @ 128Ppi - PNG
Leather Brown - 01.zip [3.33 MiB]
Downloaded 707 times
PostPosted: Sat Sep 12, 2026 9:06 am  (#5)
:jumpclap :jumpclap :jumpclap
I really enjoyed following your tutorial, TeaMouse. It’s another gem.
Now I don't know which of the two methods I like better.
I have had to reduce the size to be able to post the outcome.
Thank you so much for it, and for the time and patience you put into preparing this step-by-step tutorial.
Many thanks, TeaMouse. :tyspin :clap
PostPosted: Sat Sep 12, 2026 9:51 am  (#6)
Try using a filter sketch first, then apply the cross hatch on top of that.
PostPosted: Sat Sep 12, 2026 9:06 pm  (#7)
The Original Image.
Filter Sketch Only.
Frame for a 6" x 9" @ 128 PPI - PNG
Leather Black - 01.zip [2.53 MiB]
Downloaded 622 times
PostPosted: Sat Sep 12, 2026 9:08 pm  (#8)
Filter Sketch with the original image colors applied.
Frame for a 6" x9" @ 128 PPI - PNG
Leather Red - 01.zip [3.23 MiB]
Downloaded 618 times
PostPosted: Sun Sep 13, 2026 2:54 am  (#9)
Beautiful outcomes, TeaMouse. I am using 2.10.36 version. Where I have my favourites filters. :)
PostPosted: Sun Sep 13, 2026 9:55 am  (#10)
Autum_Nature_Filter_Sketch_+_Cross-Hatch_Sketch-on_Issa.jpg [ 2.05 MiB | Viewed 19580 times ]
PostPosted: Tue Sep 15, 2026 1:17 am  (#11)
one more :)
PostPosted: Wed Sep 16, 2026 10:53 am  (#12)
PostPosted: Fri Sep 18, 2026 1:04 am  (#13)
PostPosted: Sun Sep 27, 2026 11:34 am  (#14)
This is my attempt using a nature landscape image I created.
File comment: Before and After Image
