It is currently Fri Nov 20, 2026 1:01 pm
 Post subject: Painting noses
PostPosted: Thu Mar 27, 2014 2:26 am  (#1)
Painting another body part again. This time its:
Noses are strangely more difficult to comprehend than eyes, at least for me. The form is much more complex and is difficult to get right. I draw these noses with a use of reference. I'm just not that much comfortable drawing them from the mind. Well, the click - shift+click trick (for drawing staight lines) really help me a lot here.
 Post subject: Re: Painting noses
PostPosted: Thu Mar 27, 2014 4:53 am  (#2)
Very nice blending and realistic. Ralmon Meril.
PostPosted: Thu Mar 27, 2014 11:11 am  (#3)
You are doing pretty well with your noses. I think most people find them difficult. I don't know if it will help but I did a PDF tutorial on painting noses you might want to adapt to your own style.
viewtopic.php?f=23&t=6800
PostPosted: Thu Mar 27, 2014 12:09 pm  (#4)
Good noses! These tutorials might help you with the nose anatomy too.
Nose Anatomy Tutoral
How To Draw A Nose Step By Step
And I recommend Erisian's tutorial it helps me a lot! :D
PostPosted: Thu Mar 27, 2014 1:38 pm  (#5)
ralmon meril: good work on those noses! i have lots of problems with them myself, but like moko i learned a lot from erisian's nose tutorial.
PostPosted: Thu Mar 27, 2014 6:51 pm  (#6)
Molly: Thanks. I like it too. I'm still experimenting when I did these trying out the brushes and so. I really like how the first nose turns out. I like to use it in future paintings.
Erisian: I looked at your tut. Your style is very different from mine (though I am still developing mine with each of my paintings looking diffent from each other). I use very few layers (often only 2) and don't paint in black and white then color it but work in color.
Mokonafan: Proko has great set of tutorials! Bookmarked! His videos also makes good reference, just pause in different places and you'll get various positions for the nose. Discovered great sources for references - Videos! I had some movies here. It is essentially a treasure trove.
AnMal: Thanks! Working really hard in them. My first tries really sucked :bluesad .
