It is currently Fri Nov 20, 2026 1:00 pm
 Post subject: Speed Odometer with gimp.(fuel gauge added)
PostPosted: Sun Mar 30, 2014 1:44 pm  (#1)
I'm not sure where the idea came from but as i was messing with gimp today i got an idea to try and make a speed odometer. I think it turned out ok. Its kinda refreshing to get away from landscapes for a while.
 Post subject: Re: Speed Odometer with gimp.
PostPosted: Sun Mar 30, 2014 1:47 pm  (#2)
Looks good. :bigthup
Could use and extra beveled ring on the outside. Even so nice work. ;)
PostPosted: Sun Mar 30, 2014 1:57 pm  (#3)
Very nice RD. The colors are cool but as Wallace mentioned. An outside bevel would give it some depth.
PostPosted: Sun Mar 30, 2014 2:00 pm  (#4)
i added an outer ring. not sure if it works or not.
PostPosted: Sun Mar 30, 2014 2:01 pm  (#5)
Yeah, like this...
PostPosted: Sun Mar 30, 2014 2:02 pm  (#6)
There you go! :jumpclap
The outer ring I added was much smaller.
PostPosted: Sun Mar 30, 2014 2:05 pm  (#7)
yea it needed it. :bigthup
PostPosted: Sun Mar 30, 2014 2:41 pm  (#8)
:yes
Now your ready for the dashboard volts, water, fuel and oil gauges. :hehe
PostPosted: Sun Mar 30, 2014 7:23 pm  (#9)
Fuel gauge added.....
PostPosted: Sun Mar 30, 2014 7:39 pm  (#10)
:jumpclap
 Post subject: Re: Speed Odometer with gimp.(fuel gauge added)
PostPosted: Mon Mar 31, 2014 12:32 am  (#11)
RPM Gauge added.... :) :)
PostPosted: Mon Mar 31, 2014 2:05 am  (#12)
:kpix
PostPosted: Mon Mar 31, 2014 2:22 am  (#13)
These look really very nice. I immediately got this idea to make some fun type meter, like " sense "-o meter, " respect"-o-meter .. things like that. Might be tricky, as then it's needed to have a symbol for " sense " or " respect " haha. Anyway, very well done :)
PostPosted: Mon Mar 31, 2014 4:24 am  (#14)
Very nice! :bigthup
You have room for one more gauge there. :hehe
