It is currently Thu Nov 19, 2026 9:22 am
 Post subject: Embroidary patch of Wilber.
PostPosted: Tue Jan 18, 2011 7:46 pm  (#1)
Found a cool way to create this look using G'MIC B&W Hard Sketch and a lot of layer blending, but still, only takes a few minutes to do. :)
 Post subject: Re: Embroidary patch of Wilber.
PostPosted: Wed Jan 19, 2011 4:56 am  (#2)
There is a nice little utility that does embroidery really well, fortunately it works very well with inkscape it's called DRAWWings Embroidery effects, sadly i got s 404 when I tried to get the link, hopefully it's temporary.
PostPosted: Wed Jan 19, 2011 4:59 am  (#3)
thats really cute
PostPosted: Wed Jan 19, 2011 8:36 am  (#4)
you can dl the evaluation version here,
http://www.drawstitch.com/index.php/Dow ... valuation/
you have to register and they send you a link in your email.
The Evaluation Edition
The Evaluation Edition of DRAWings® 4 shall give users a general understanding of the software, although certain features and tools are disabled in the Evaluation Edition. Please also note that neither the 3 modules (Basic, Text, and Connect) of Wings’ modular® software nor the other complimentary products which are included in the DRAWings® 4 package are available in the Evaluation Edition. Nevertheless, you can Use the Evaluation Edition to:
* Create New or Edit Existing vector graphic designs and export them as Scalable Vector Graphics format (.svg);
* Trace bitmap automatically and convert it to editable Vector designs.
* Manually vectorize or digitize bitmap images. Export as .svg;
* Convert any graphics vector design or bitmap or stitch file to embroidery (without the ability to save the stitch file) for printouts; Export as jpg, bmp, etc.
* Convert Stitch files to Vector designs (e.g. ".dst" To ".svg") and edit them (node editing etc.)
* Open ".DRAW" files and export the Embroidery image (.png, .bmp, .tiff and .jpg) for any graphics designing use.
* Create graphics and apply Embroidery Effects for inkjet printing, engraving as well as other applications in apparel embellishment.
it also comes in a Corel Draw plug-in version for free.
PostPosted: Wed Jan 19, 2011 10:32 am  (#5)
Sophie Sew is kinda cool. =) - not to mention free
http://www.sophiesew.com/SSDLP/Gallery.php
PostPosted: Wed Jan 19, 2011 10:52 am  (#6)
I wonder if you could use the new lines along a path to do this?
http://registry.gimp.org/node/25000
PostPosted: Wed Jan 19, 2011 11:46 am  (#7)
Some cool links. Still glad that G'MIC can sort of mimick the look without having to use a third party plugin or stand-a-lone. :)
PostPosted: Wed Jan 19, 2011 3:40 pm  (#8)
Drawigs embroidery is free, i forgot to mention that. It's funny about what formats it works with but it works perfectly with inkscape.
PostPosted: Wed Jan 19, 2011 4:08 pm  (#9)
Did you buy the software? The site is now called DRAWStitch.com http://www.drawstitch.com/index.php/Pro ... _it_works/
I like that embroidery image, Gms9810. I am originally from Missouri, I went to the University of Central Missouri (formerly CMSU).
PostPosted: Wed Jan 19, 2011 10:21 pm  (#10)
Thanks Mahvin; did a quick test and it is pretty cool. :)
PostPosted: Thu Jan 20, 2011 5:19 pm  (#11)
I like that embroidery image, Gms9810. I am originally from Missouri, I went to the University of Central Missouri (formerly CMSU).[/quote]
No, the version I have is freeware. I'm about 80 miles south of St louis, if you're familiar with that area. Before I retired I worked for the MSU system, I worked at UMSL.
