It is currently Fri Nov 20, 2026 1:05 pm
 Post subject: Re: Super Green (Test)
PostPosted: Sat Apr 19, 2014 4:01 pm  (#1)
conbagui wrote:
Just Testing... :cofscreen
I feel that the text would look better with a yellow outline.
PostPosted: Sat Apr 19, 2014 4:25 pm  (#2)
conbagui wrote:
Hi Wallace, You mean the text inline?
Inline?
No... The text "outline".
The outer most edge of the text. I feel would look much better with a yellow (#ffa800) outline.
PostPosted: Sat Apr 19, 2014 6:46 pm  (#3)
Just curious, what does "testing" mean? Testing to see if there's enough response to do a tutorial? Just wondering is all. Thanks.
PostPosted: Sun Apr 20, 2014 12:22 am  (#4)
conbagui wrote:
Well... that could be one of the reason. I write testing because, there is still room for improvement, to make the effect better. Thanks for asking Warrior. :)
Oh, okay, that makes sense. :bigthup
