It is currently Fri Nov 20, 2026 1:04 pm
 Post subject: Re: Wilbert's sphere
PostPosted: Sun Apr 27, 2014 12:42 am  (#1)
Great works :yes
all the best
dulie
PostPosted: Sun Apr 27, 2014 6:56 am  (#2)
conbagui, you're acquiring such a skill to draw crystal balls that if you persist on this path some time from now you will be able to predict the future.
PostPosted: Sun Apr 27, 2014 11:36 am  (#3)
You are right Carlos, Conbagui is actually a master giving effects or creating texts, well anything he wants to do. :paint
PostPosted: Mon Apr 28, 2014 7:34 am  (#4)
conbagui, I learned a lot of Map>Map Object from this ccbarr's tutorial:
Spinning Gimp Coin
PostPosted: Mon Apr 28, 2014 7:48 am  (#5)
I did that one a couple years ago Carlos. I like all ccbarr's tutorials, he is excellent at explaining things as he goes.
