It is currently Fri Nov 20, 2026 1:03 pm
 Post subject: Re: Chewing Gum Text -"YUCK"
PostPosted: Mon Apr 28, 2014 7:24 pm  (#1)
Conbagui yes it's cool an would look nice on an asphalt background
 Post subject: Re: Chewing Gum Text -"YUCK" Updated
PostPosted: Mon Apr 28, 2014 11:42 pm  (#2)
You need a foot print. :hehe
PostPosted: Tue Apr 29, 2014 12:35 am  (#3)
you need a footprint on asphalt.
PostPosted: Tue Apr 29, 2014 1:01 am  (#4)
Cool :bigthup - looks complicated.
PostPosted: Tue Apr 29, 2014 3:34 am  (#5)
It's a good job, Conbagui. I'd like to know how to do it. The only problem is when this stuff sticks in my shoe, I always get nervous if it happens. :hehe
PostPosted: Tue Apr 29, 2014 10:19 am  (#6)
That's sweet(no pun intended), I think it's a bit contrasted though, the whole image needs more ambient light to look realistic. What layer FX are you using?
PostPosted: Tue Apr 29, 2014 12:12 pm  (#7)
Haha, no, I didn't mean what version of Layer FX you were using, I meant which effects from LayerFX are you using, bevel and emboss?
PostPosted: Wed Apr 30, 2014 12:05 pm  (#8)
Nice one, If your interested I did a design using some footprints, I'll post the xcf here for you to look at.
Shoe Template.xcf [638.55 KiB]
Downloaded 71 times
