It is currently Fri Nov 20, 2026 11:06 am
 Post subject: Wallpaper(s) - New Added!
PostPosted: Wed May 07, 2014 4:08 pm  (#1)
I added a wallpapers page for my game (kinda ambitious I know but I am trying to make myself feel important even if nobody else thinks so. LOL) and I made 1 so far for the music (because the composer I want to make extra nice wallpapers for as a thank you type thing and help him get more publicity!) and 1 for my game but changed the background color so I have 4 for my game.
Old:
Music:
The hearts are supposed to be speakers.
Game:
Some New:
Link
CnC welcomed, Enjoy!
~ God Bless ~
~ Moko
 Post subject: Re: Wallpaper(s)
PostPosted: Wed May 07, 2014 9:02 pm  (#2)
I'll grab sm :jumpclap
PostPosted: Thu May 08, 2014 3:22 am  (#3)
Beautiful Moko, beautiful!
PostPosted: Thu May 08, 2014 3:36 am  (#4)
beautiful indeed! Well done Moko! :clap :paint
PostPosted: Thu May 08, 2014 4:36 am  (#5)
Complimenti, Mokonafan. The wallpapers you created for your game look very beautiful and accurate. :bigthup
Best wishes for the continuation of your project.
PostPosted: Thu May 08, 2014 7:59 am  (#6)
Beautiful work.
PostPosted: Thu May 08, 2014 4:08 pm  (#7)
Thank you for all the kind comments! :D
PostPosted: Thu May 15, 2014 9:42 pm  (#8)
These looks very good, great job! I do have a few comments on how they could be improved a bit.
1:
I like the theme you were going for here, although there are some QoL changes that would blend the composition together a little better. First off, the reflections for the hearts doesn't line up perfectly under the hearts. If you wanted it to seem like there was a little bit of a displacement you should distance them from the main hearts or just match them up perfectly. Also, if you were going for a reflection you should maybe thinking about having the reflected hearts blend out into transparency by using a layer mask then using a simple white to black gradient.
2:
I really like the simplicity of the piece, however it may be just a bit too simple. I would suggest adding a little bit of a texture of some kind as an overlayed layer over the base layer in order to help it seem more like a background and not be too distracting from the overall design. Other than that you may want to add a gradient to the background to darken the edges to put the focus more on the text. The way I would accomplish this would be to create a new layer, change your foreground to white, background to black, and stoke a radial gradient with the focal point on the text, then set that layer to soft light and lower the opacity. This would just help to put the focus more on the text. Other than those minor things however the composition looks great and works very well overall.
Good job on both pieces!
 Post subject: Re: Wallpaper(s) - New Added!
PostPosted: Wed Aug 27, 2014 2:18 pm  (#9)
:tyspin
Some New:
PostPosted: Wed Aug 27, 2014 2:33 pm  (#10)
Lovely stuff Moko, you've been busy. :bigthup
PostPosted: Wed Aug 27, 2014 3:25 pm  (#11)
excellent creations, Moko!
PostPosted: Thu Aug 28, 2014 3:09 pm  (#12)
:tyspin both
