It is currently Fri Nov 20, 2026 12:29 pm
 Post subject: This is GIMP wishy ...
PostPosted: Thu May 08, 2014 8:32 am  (#1)
Hi,
How sweet to have a simple tools lay-out in GIMP that could detached, positioned and even flipped.
The original position of the tools is right below the menu bar.
:gaah :bump
 Post subject: Re: This is GIMP wishy ...
PostPosted: Thu May 08, 2014 8:35 am  (#2)
good arrangement
PostPosted: Thu May 08, 2014 9:26 am  (#3)
Oooh I like that!
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Thu May 08, 2014 9:47 am  (#4)
Very clever. I have never been able to get that thin tool bar. How do you do it?
PostPosted: Thu May 08, 2014 9:57 am  (#5)
Also included a detachable brush dialog.
Sorry Sallyanne, it's a fantasy.
PostPosted: Thu May 08, 2014 10:01 am  (#6)
And of course a detachable brush dialog.
Must beable to do it I am sure I have seen it on someone else's gimp.
PostPosted: Thu May 08, 2014 10:13 am  (#7)
Of course yes.
You might be right if you're referring to GIMP's native multiple windows as in the attached screenshort.
All you do is to close all other dockable dialogs under the tools, then under "windows" in the menu bar on top of GIMP uncheck the button that says "single-window mode". After that you will have multiple windows, just need to resize your tools dialog and resize it as you desire.
Done.
However, its not possible if you need a floating tools box or brush dialog in single-window mode.
PostPosted: Thu May 08, 2014 10:56 am  (#8)
Thanks again
PostPosted: Thu May 08, 2014 11:57 am  (#9)
You're wellcome Sallyanne.
PostPosted: Thu May 08, 2014 12:20 pm  (#10)
Windows>Dockable dialog>Brushes ?
PostPosted: Thu May 08, 2014 12:55 pm  (#11)
Maybe someone should rewrite the old deweirdifyer plugin and bring it up to date.
Then again maybe not.
