It is currently Fri Nov 20, 2026 1:02 pm
 Post subject: multi-replicate filter
PostPosted: Fri May 30, 2014 11:33 am  (#1)
3 minutes exercise with multi-replica filter
after you put some little white forms on black bkg in the left-top-corner
and with image mode GRAYSCALE change also the mode layer to DIFFERENCE call MULTI-REPLICAte filter in Edit menu; default setting except
number of copies 16
starting angle.... 22.5
incremental angle...22.5
merge layers...click
plus some cosmetic adjustment and voila you can have a similar result!
let me know if you want more details
 Post subject: Re: multi-replicate filter
PostPosted: Sat May 31, 2014 6:03 am  (#2)
my play, Marcello
thanks
PostPosted: Sat May 31, 2014 3:06 pm  (#3)
whoooo....you are a master!
PostPosted: Sat May 31, 2014 6:56 pm  (#4)
original layer
settings
result
other exerc.
PostPosted: Sun Jun 01, 2014 5:47 am  (#5)
Grazie Marcello. :)
Thanks for using my script.
The results you posted, as well as those of dinasset, look very cogent and emphasize the fact that with the script it is even possible to produce kaleidoscopic effects if you adjust the starting layer's properties and the script's settings in the appropriate manner.
PostPosted: Sun Jun 01, 2014 10:33 am  (#6)
your filter is very interesting maybe at the beginning is not very easy but after
it gives a lot of satisfaction
Gino, sei stato molto bravo nel crearlo e documentarlo!
other exerc.
