It is currently Fri Nov 20, 2026 1:06 pm
 Post subject: Gimp Deco
PostPosted: Sun Jun 08, 2014 7:21 am  (#1)
I'm getting quite interested in Art Deco at the moment and put this together from a photoshop tutorial. The one thing that I had quite a bit of trouble with was the fan shapes at each corner. Couldn't find any way of making the shape via any of the filter so had to make a circle, then a wedge shape using the path tool, used this to delete a segment of the circle and then moved the selection by 10 pixels, setting the pivot point as the narrow point of the wedge, and deleted a segment again. After deleting all the required segments I had to make a circle selection over the rough outer edges of the fan, then inverted and deleted.
Just wondering if anyone knows of a better way to create the fan shape. I've tried a few of the path shape tools but not had much luck with getting the right shape via that method.
I think the font could do would some more work, just a bit of a quick fix that one.
DeviantArt gallery
 Post subject: Re: Gimp Deco
PostPosted: Mon Jun 09, 2014 1:08 pm  (#2)
Now - it is simple
Arakne-path-shape-creator6a
http://www.arakne.es/en/dessign/gimp-shape-creator-6a-error-corrections-and-new-shapes/
PostPosted: Mon Jun 09, 2014 2:43 pm  (#3)
Very nice MareroQ. :bigthup
PostPosted: Mon Jun 09, 2014 2:45 pm  (#4)
I love the font, very nice caz
PostPosted: Mon Jun 09, 2014 2:47 pm  (#5)
very nice MareroQ
PostPosted: Tue Jun 10, 2014 7:13 am  (#6)
You can try this script.
elsamuko-escape-lines.scm.zip [1.81 KiB]
Downloaded 153 times
PostPosted: Tue Jun 10, 2014 7:37 am  (#7)
Thank you Carlos. I'll try it.
PostPosted: Tue Jun 10, 2014 7:48 am  (#8)
Very nice Caz. Must have taken awhile. Good finish, The text looks good too. :)
PostPosted: Tue Jun 10, 2014 8:32 am  (#9)
MareroQ wrote:
are there still bugs in arakne?
downloaded ...creator6a
when I launch the path creator on a new image, I get a heart (default)
if I only just change the shape to -let's say- star, I immediately get:
path shape creator Warning
float division by zero
list index out of range
PostPosted: Tue Jun 10, 2014 11:02 am  (#10)
Additional info (made some other tests):
these are the shapes that - when selected - produce a gimp error on the console:
-flower
-star
-gear
-arc
-spiral
-cross
-polygon
all the others show up
in the folder "shapes" all are in, both those which show up and those which go into an error.
PostPosted: Tue Jun 10, 2014 12:39 pm  (#11)
Hi Caz I really like your idea and your corners. I was thinking that there are free border/corner fonts (dingbat fonts) that might help. I understand your wanting it to be original but perhaps it could work.
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Tue Jun 10, 2014 12:51 pm  (#12)
Dinasset, I can run it all right and no error. May you download it again? perhaps it helps.
Dalia, I love your corners in your outcome. :clap
PostPosted: Tue Jun 10, 2014 1:01 pm  (#13)
downloaded twice already, same results
(maybe there is something on my system that generates problems with "special" python plug-ins - by "special" I mean not being a simple single python file...)
I'll try again tomorrow, thanks for your help
PostPosted: Tue Jun 10, 2014 1:21 pm  (#14)
Hi Diego - for me it's just information.
When you enter values ​​are still not working?
The actual small mistake, however, occurred (for squares and rectangles - the option Corners: "Rounded inverse" and "Chamfer" stopped working - was reported to the author).
PostPosted: Tue Jun 10, 2014 1:38 pm  (#15)
Very interesting Mareroq!
It seems that the plug-in starts working without entering OK.
So, in the example you asked:
1-changed shape (w/o hitting OK) = errors shown
2-entered petals > 0 (w/o hitting OK) = errors shown
3-entered radius > 0 (w/o hitting OK) = errors shown
4-entered rotation > 0 (w/o hitting OK) .... et voilà the flower!!!
What's the matter?
PostPosted: Tue Jun 10, 2014 2:01 pm  (#16)
Sometimes (rarely) it happens (at startup) that a shape is "resistant" to change a specific parameter - that I click another (changing value) and it starts to work without a problem.
A small drawback - but the possibility of the plugin are now Excellent.
PostPosted: Tue Jun 10, 2014 2:06 pm  (#17)
yes, but: is it "natural" that without entering OK the plug-in starts working?
it's not usual, for me, at all.
do you know other plug-ins doing the same?
or - even better : do you know how to avoid this behaviour in this plug-in?
PostPosted: Tue Jun 10, 2014 2:16 pm  (#18)
I love Art Deco designs. I think you've captured the look with this image. :grinyes
PostPosted: Tue Jun 10, 2014 2:44 pm  (#19)
Diego - I think you should move our discussion to another thread.
As for me, the shape is only displayed (the time when you click add shape - and then you see already two path - but only one shape has been saved)
Take the test:
after the first run (when the shape is displayed) - when you press Cancel - the path is displayed?
PostPosted: Tue Jun 10, 2014 2:58 pm  (#20)
I'm talking about error messages, not about layers.
You may see what I mean just selecting flower shape (after the plug-in is called for the first time showing the heart) but having open the gimp console
anyhow, you are right
this discussion is out of the topic, somehow, it's related to a specific plug-in
i've also written to the author
have a good night, for now and thanks for your support
