It is currently Fri Nov 20, 2026 1:05 pm
 Post subject: Re: Pretzel Text
PostPosted: Sun Jun 15, 2014 3:48 am  (#1)
Great effect! :)
PostPosted: Sun Jun 15, 2014 7:23 am  (#2)
I like it! Very:coolthup
PostPosted: Sun Jun 15, 2014 8:16 am  (#3)
Nice work conbagui.
PostPosted: Sun Jun 15, 2014 12:36 pm  (#4)
Conbagui, I like that effect, too. But I haven't seen the one about bread. did you do it? Thank you so much. :tyspin
PostPosted: Sun Jun 15, 2014 12:39 pm  (#5)
:lol
Nummy. :3
PostPosted: Sun Jun 15, 2014 1:52 pm  (#6)
Thanks, yet again, for the inspiration.
My variation on Pretzel Text.
PostPosted: Sun Jun 15, 2014 7:45 pm  (#7)
I just created a seamless pattern (from an image of a pretzel) and used Logo Toolbox to create the filled, stroked, beveled text, with a drop shadow. This is my standard approach to creating any kind of texture filled text. I'll create a seamless fill pattern of whatever texture I'm planning to use.
Additionally for this effect, I used GC shadow to create a slight inner glow and as a final step, just to add a little more depth, I applied a some relief light using G'MIC.
File comment: Seamless Pretzel Pattern
File comment: Pretzel Text XCF
pretzel-text-lt.xcf [2.74 MiB]
Downloaded 122 times
PostPosted: Sun Jun 15, 2014 11:41 pm  (#8)
I like your approach. It's a bit more "artsy" than my brute force result. :hehe
I find that sometimes, it can be hard to create a seamless texture that works well for the design. It seems to depend on the image from which you're sampling the texture and how the image's surface is patterned.
