It is currently Fri Nov 20, 2026 1:06 pm
 Post subject: Key to Her Heart
PostPosted: Fri Jul 11, 2014 6:41 am  (#1)
Designed this at the request of a friend. I think the text would have looked nicer running up the left side but he wanted on top. Still think it looks nice though.
 Post subject: Re: Key to Her Heart
PostPosted: Fri Jul 11, 2014 7:19 am  (#2)
Very nice Jeanniem :bigthup
PostPosted: Fri Jul 11, 2014 8:04 am  (#3)
I like it jeanniem, it's very nice. :hi5
PostPosted: Fri Jul 11, 2014 8:39 am  (#4)
The unromantic person in me says that you can't turn that key without getting your fingers pricked :)
The keyhole seems a bit big for the key, the roses look a bit weird on the right of the key (there is a leaf poking out of the heart) and I agree that the sides would have been a better place fort he text.
Nice work on the shine on the heart even if there is a bit of aliasing still visible on the left.
Balanced and elegant, with just the right amount of foliage.
PostPosted: Fri Jul 11, 2014 10:31 am  (#5)
Thanks ofnuts, I hadn't noticed the vine sticking out. Now I just have to figure out how to fix it, being that the vines and heart are all on one layer
PostPosted: Fri Jul 11, 2014 12:05 pm  (#6)
Thank you ofnuts for pointing out the problem with the vine, I totally missed it. I found the best way to fix it is to cover it with a butterfly which really added a much needed pop of color. My friend wanted his girlfriends name in gold so I changed that too. I know it looks a little blurry but I had to scale it down in order to post it
PostPosted: Fri Jul 11, 2014 1:56 pm  (#7)
That is a beauty!
