It is currently Fri Nov 20, 2026 12:12 pm
Post new topic Reply to topic  [ 52 posts ]  Go to page 1, 2, 3  Next
 Post subject: sharing outcomes - machinery (challenge)
PostPosted: Sat Jul 12, 2014 2:23 am  (#1)
Hello friends, here there is a new challenge. What can be done on a photo as this one? Here my first try. :)
Please, remember I'm still learning, so explain your procedure for me to learn. :) :tyspin
From original at Requiem for Industory - Kazuhiko Nakamura
 Post subject: Re: sharing outcomes - machinery (challenge)
PostPosted: Sat Jul 12, 2014 3:06 am  (#2)
First thing I did was texture enhance. Alittle bit of curves, colour balance - less yellow and green.
Finally added a little contast and brightness.
PostPosted: Sat Jul 12, 2014 3:11 am  (#3)
Thank you Sallyanne, a good outcome. :clap
PostPosted: Sat Jul 12, 2014 6:22 am  (#4)
my first trial
a little dramatic
PostPosted: Sat Jul 12, 2014 7:01 am  (#5)
I don't know why, but this machinery inspires me to be dramatic!
Another trial, even more dramatic...
edit:
retinex (two separate layers, low and high)
added two layers on top, both with gradient "aneurism", different distance
PostPosted: Sat Jul 12, 2014 7:52 am  (#6)
Dinasset, both of your outcomes are very good. I like more the last one. I'm still practising the one Sallyanne did, then I'll try to do yours.
Thank you :tyspin
PostPosted: Sat Jul 12, 2014 8:07 am  (#7)
my first experiment came out simply by painting over, so nothing really interesting to reproduce.
With gradients, instead, you may get a lot of interesting results.
At least, for such a kind of picture...
PostPosted: Sat Jul 12, 2014 10:10 am  (#8)
Sallyanne, did you get any problem when you ran texture enhance filter? I get it stops and does nothing. Does the filter take long time to get it?
PostPosted: Sat Jul 12, 2014 10:56 am  (#9)
SallyAnne is likely sleeping...
I tried to use that filter
At least with the standard parameters the answer is immediate!
PostPosted: Sat Jul 12, 2014 11:13 am  (#10)
When I run the filter is immediately stop, and it does nothing. It must be mine that doesn't work. well, I'll try your methods about gradients. Thank you again. :)
PostPosted: Sat Jul 12, 2014 11:55 am  (#11)
which version of Gmic do you have?
And -in any case- did you "refresh" the filters? (the little symbol between the + and internet)
PostPosted: Sat Jul 12, 2014 12:12 pm  (#12)
Here my capture screen. I've actualized GMIC and nothing.
PostPosted: Sat Jul 12, 2014 12:26 pm  (#13)
My try with gradients, aneurism one.
PostPosted: Sat Jul 12, 2014 12:38 pm  (#14)
1) about Gmic filter: I don't understand, it seems everything OK (unless you have more than one Gmic). Could you try -as last hope- to use it on a very small image?
2) about machinery: well done! try also other gradients, many produce interesting results!
PostPosted: Sat Jul 12, 2014 12:49 pm  (#15)
Right! I tried it with a smaller size it worked at once. :clap
PostPosted: Sat Jul 12, 2014 12:52 pm  (#16)
everything OK what ends OK ...
PostPosted: Sat Jul 12, 2014 12:59 pm  (#17)
interesting image.
Here's my try.
I just played with color balance, and then applied Unsharp Mask on the "DDD" layer of Luminosity Masks.
Another try.
Select everything except the smoke, and played with color balance.
PostPosted: Sat Jul 12, 2014 1:07 pm  (#18)
Issabella, look, gimp-chatters are attracted by that strange machinery you posted!
you'll see a lot of "variations" on the subject.....
it's a challenge to get an interesting outcome, easy to get strange ones (like mine also are), more difficult to get fascinating ones...
there is still time!
PostPosted: Sat Jul 12, 2014 1:20 pm  (#19)
I like your outcome Tin, a dramatic one with an attractive colour. Well! this is getting very interesting when the best people are doing their art. :jumpclap
PostPosted: Sat Jul 12, 2014 1:27 pm  (#20)
I am curious to see Pat David try and see what he comes up with.
It's such an interesting image to play with.
here's another try
I wanted the sky to have a different color to make the machine stand out a little more. so i selected the sky around the machine and gradient masked it. and colorize the sky blue.
