It is currently Fri Nov 20, 2026 12:11 pm
 Post subject: Creating a glass ball with Gimp or Lens distortion
PostPosted: Mon Jul 28, 2014 4:04 pm  (#1)
Hi to all
Here a simple Image from my Garden manipulate with Gimp and Lens Distortion
i found this Tutorial on a YouTube Channel Creating a glass ball with Gimp
Note: This Tutorial is in German Lang
Here my Result i have make more from it.
greetings
groni
I am comfortable with Linux as a penguin in the water
A Day without working with Gimp is a very very bored Day (groni g)
 Post subject: Re: Creating a glass ball with Gimp or Lens distortion
PostPosted: Mon Jul 28, 2014 4:08 pm  (#2)
Thank you groni g. :)
PostPosted: Mon Jul 28, 2014 4:12 pm  (#3)
Great idea!
PostPosted: Mon Jul 28, 2014 5:09 pm  (#4)
too bad it's in German, so i missed many steps. otherwise i'd post my try here.
PostPosted: Mon Jul 28, 2014 5:25 pm  (#5)
This tutorial is the same used by Ella Louise at My Island.
A great tutorial!
Groni, your garden is beautiful, creative decor! ;)
bbbbbbbbbbbImage
PostPosted: Mon Jul 28, 2014 5:48 pm  (#6)
Tin,
One option is the Manhatten Graechan's Script.
viewtopic.php?f=9&t=9933&hilit=manhattan
bbbbbbbbbbbImage
PostPosted: Mon Jul 28, 2014 6:04 pm  (#7)
Very nice. I wish I understood German. :ffy
PostPosted: Mon Jul 28, 2014 9:43 pm  (#8)
Did you turn the globe upside down Conbagui?
PostPosted: Mon Jul 28, 2014 11:23 pm  (#9)
True, it looked a little different to groni's. I will check the tutorial out soon. ;-)
Nice garden groni :bigthup
PostPosted: Tue Jul 29, 2014 2:27 am  (#10)
Thank you
The german lang is not the Problem i make it today again in English lang
so can all understand it
@conbagui
Very good result
@akros
Thank you
I'm very proud to have a garden
PostPosted: Tue Jul 29, 2014 3:32 am  (#11)
for lazy users
version 2 of Globe-View
added: the possibility to flip the globe
added: the option not to zoom-blur the background (if user does not like it)
original image (thanks to Issabella)
"globed-flipped" using the Globe-View2
version 2 of the script
DIEGO_Globe-view2.7z [2.24 KiB]
Downloaded 154 times
PostPosted: Tue Jul 29, 2014 4:17 am  (#12)
Thank You dinasset
for the script DIEGO_Globe-view2.7z [2.24 KiB]
I have Test it with a Garden Image here the Result
File comment: Here the Settings
and here the result with origin settings i have set a hook on "Want to zoom-blur the background"
File comment: The result from the Image
good script for working
PostPosted: Tue Jul 29, 2014 7:40 am  (#13)
Tin and Oregonian, I suppose it’s mostly the specific terms that you don’t understand in German.
I’ve tried to translate them in English.
If there is something not understandable please look at the video tut, pictures can tell a lot sometimes.
groni g, I hope you’re not offended by it. I made this tut many times in English already.
open your image and add an alpha chanel if there isn't one
duplicate the image
filters >> distorts >> whirl and pinch
with these settings
filters >> distorts >> apply lens
make surroundings transparent
lens refraction index 2,20
layers >> scale layer
uncheck the chain and make the layer square (I made 310x310)
layer >> transform >> rotate 180°
layer >> scale layer to image size
alpha to selection
select >> invert
filters >> light and shadow >> drop shadow
blur radius about 1/3 or a bit more the globe size
uncheck allow resizing
select >> none
dropshadow layer >> layer to image size
colors >> colorize
new transparent layer
alpha to selection on sphere layer
highlight te new layer
gradient >> white to transparent >> shape >> shaped spherical
apply the gradient like in the video-tut
select >> none
layermode >> overlay
new tranparent layer
use the ellips tool to draw an ellips
gradient shape on linear
draw a line >> layermode >> grain merge
all layers to image size
I suppose you can understand how to make the new star-brush.
How to move the sphere you can see on the video- tutorial.
PostPosted: Tue Jul 29, 2014 8:03 am  (#14)
Hi! Ella Louise
No i'm not offended
It is good to see that you have make it in English so have we no double post here and you write better English as i.
:tyspin for doing it
PostPosted: Tue Jul 29, 2014 8:07 am  (#15)
But your German will be better than mine, groni g :)
My native language is Dutch.
PostPosted: Tue Jul 29, 2014 8:57 am  (#16)
for lazy users
Thank you. I've been using version 1 for a while. Nice script (arm chair tools) Dinasset. Also makes great sphere maps.
PostPosted: Tue Jul 29, 2014 8:58 am  (#17)
Thanks for translating Ella Louise.
PostPosted: Tue Jul 29, 2014 11:02 am  (#18)
here's my try (thanks Ella Louise)
I think i might have screwed up on the ellipse step, and then my star brush has 6 points intead of 4.
PostPosted: Tue Jul 29, 2014 11:48 am  (#19)
@Tran, I think you used the brush for creating the orange (conbagui’s tut).
For the sparkles you have to create a new brush.
Click on this icon in the brushes menu.
There will appear a new window.
You have to change it with the following settings.
First click on the rhombic icon, then change the numbers.
There you have your new brush.
PostPosted: Tue Jul 29, 2014 1:02 pm  (#20)
Nice tutorial. :2thup
I just wanted to point out another interesting thread on creating Glass Spheres that members might find useful. :cool
