It is currently Fri Nov 20, 2026 12:11 pm
 Post subject: Thermal Imaging plus Gradient
PostPosted: Mon Aug 04, 2014 11:03 pm  (#1)
Was bored and thinking of something to try out in Gimp, a fake thermal image seemed a easy enough try, so I created a gradient (which you can download at the end of this post) and set about colouring an image in depth map style but using black as coldest and white as the hottest parts of the image. I then mapped to my new gradient and gave the image a slight blur.
I'll admit the image is all a bit rushed but just wanted to get something done to show you the potential of this gradient.
Below is my image from Original to Greyscale to Gradient Mapped.
Thermal-Image.ggr [26.37 KiB]
Downloaded 353 times
 Post subject: Re: Thermal Imaging plus Gradient
PostPosted: Tue Aug 05, 2014 3:05 am  (#2)
How does it actually work? Do pictures have heat signatures?
Anyhow neat job :bigthup
PostPosted: Tue Aug 05, 2014 3:58 am  (#3)
Lovely effect he4rty!
PostPosted: Tue Aug 05, 2014 5:26 am  (#4)
Not sure if I did it correctly.
This is what I got using your gradient with colour > map > gradient map.
Of course I checked the gradient before I ran it.
No it's not the same. I just tried it on your original. Got a different result, so how did you do it?
Just figured what I did wrong. Depends on the greyscale pic.
Here it is again
PostPosted: Wed Aug 06, 2014 12:56 am  (#5)
Erisan - Thanks for the comment
Sallyanne - Nice results, the greyscale image I created in the first post wasn't done using any filters or scripts but by selecting different parts of the image and filling with various greyscale gradients by using the blend tool and the shaped fill patterns. You could also use the paintbrush tool and paint the image from black to white to manually identify your own heat signatures.
