It is currently Fri Nov 20, 2026 11:09 am
 Post subject: Interface Practice followed a Photoshop tutorial.
PostPosted: Wed Aug 13, 2014 4:05 pm  (#1)
Any feedback is welcome and constructive feedback on how I can improve is always welcome.
Credit goes to Tim Silva for the tutorial and Axertion for the pattern.
 Post subject: Re: Interface Practice followed a Photoshop tutorial.
PostPosted: Wed Aug 13, 2014 5:05 pm  (#2)
Very pixellated edges all over the place... Unfortunately I cannot tell you how to avoid them since I don't know how you produced them.
PostPosted: Wed Aug 13, 2014 5:21 pm  (#3)
Thank u for letting me know that. I used the paths tool to create the shape. Then the noise filter RGB noise selected greyscale then used gaussion blur. Then I used a lot of burning, dodging and smudging. I used a lot of gradient layers.
PostPosted: Wed Aug 13, 2014 6:14 pm  (#4)
I agree with Ofnuts. - (some examples below)
The design is interesting and looks good.
Perhaps using more curves would reduce pixellated edges.
The author of the tutorial itself gives a hint in this direction:
"To avoid any pixelation, add some more white strokes and outlines around the base shape. Try using a 2 pixel, white stroke. Flatten the layer, load the "Main_base" selection. Also, let's start adding some shading to the bottom part. Repeat the broad directions behind Steps 12 - 17,"
bbbbbbbbbbbImage
PostPosted: Wed Aug 13, 2014 7:00 pm  (#5)
Thank u for showing me the pixelated edges and I'll be able to correct them in my next design. I'll do the tutorial again next time I will pay closer attention to any pixelation.
PostPosted: Wed Aug 13, 2014 10:57 pm  (#6)
Try moving the path nodes :)
