It is currently Fri Nov 20, 2026 11:06 am
 Post subject: Praying on Pluto
PostPosted: Sun Aug 17, 2014 7:42 pm  (#1)
I'm quite happy with this one... I made the planetoid surface in Sketchup, rendered in Blender, drew the figure and added her as a layer.
It is important that the image is dark, just not sure if I maybe made it a bit TOO dark...
 Post subject: Re: Praying on Pluto
PostPosted: Mon Aug 18, 2014 3:29 am  (#2)
Nice :) much better than I can do ;)
If you enlarge it you can see the image properly. Only thing I would question is....the light around the figure looks like a spotlight and the reflection shows two lights?
PostPosted: Fri Aug 22, 2014 9:39 am  (#3)
Yes, that's a bit of artistic licence I suppose, if I was making it more realistic there would be two spotlights on the surface of the ice in front of the figure, but if I did that I think it would wash out the reflection (which is an important element of the story). Also, the main figure would be even less visible, lit only from in front.
