It is currently Thu Nov 19, 2026 9:19 am
 Post subject: Bird's nest Sphere.
PostPosted: Fri Feb 04, 2011 4:14 pm  (#1)
Used Sculpture Generator, by Carlo H. Séquin, UC Berkeley, to create the wreath ring and then used GIMP to create the seamless texture and Mathmap to create the Sphere. Man, I do like Sculpture Generator; just wish it could do other things too like knots. The program is so fast at both rendering and manipulating (believe it uses the graphic acceration capabilities of the system; just has too) it's rendition too. :)
 Post subject: Re: Bird's nest Sphere.
PostPosted: Fri Feb 04, 2011 4:44 pm  (#2)
Magicians should be admired - and not think about how to do that?
However, beginners can also ask Master - a step by step effect: birds_nest.png
PostPosted: Fri Feb 04, 2011 4:47 pm  (#3)
Or how you do spheres, in general, would be sweet. I fake them with mathmap, but never seem to get the same effect as you, oh GREAT SPHERE MASTER (yes Lyle, that's you). :)
PostPosted: Fri Feb 04, 2011 5:25 pm  (#4)
I use Mathmap>Distort>Sphere Mahvin. I put a smaller texture background behind the front texture then run the Distort>Sphere preset and it automagically creates the sphere. I drop the size to 4.2 on the slider to make it more circular. Now you are a master too. :)
PostPosted: Sat Feb 05, 2011 2:57 am  (#5)
Thanks Lyle. :)
PostPosted: Sat Feb 05, 2011 5:23 am  (#6)
Former Member
That's pretty dope!
