It is currently Fri Nov 20, 2026 11:09 am
 Post subject: Phoenix Rising Using BRL
PostPosted: Fri Aug 29, 2014 1:40 pm  (#1)
I saw what Lyle had done with his Phoenix, so I had to give it a try. I used Scheme II as the emap for this image.
You can view this emap @ the link below.
http://gimpchat.com/viewtopic.php?f=12& ... 00#p144648
Phoenix image by rehsurc @ deviantArt.com http://www.deviantart.com/art/Phoenix-T ... t-58528592
 Post subject: Re: Phoenix Rising Using BRL
PostPosted: Fri Aug 29, 2014 1:46 pm  (#2)
How about the link to the template Wallace? Definitely like your result by the way. :)
PostPosted: Fri Aug 29, 2014 1:52 pm  (#3)
Here's a link to the image I used..
http://fc02.deviantart.net/fs18/f/2007/ ... ehsurc.jpg
PostPosted: Fri Aug 29, 2014 2:20 pm  (#4)
Wow Wallace, that is so very nice.
PostPosted: Fri Aug 29, 2014 2:34 pm  (#5)
Thanks Molly!
I wanted more of a fiery look to it, but what i got I'm happy with.
PostPosted: Fri Aug 29, 2014 2:41 pm  (#6)
Image ]
viewtopic.php?f=12&t=9677&start=200#p144648
Here is your fire Wallace, :teeth
PostPosted: Fri Aug 29, 2014 3:00 pm  (#7)
Image ]
Nice one Molly! :jumpclap
I thought of doing that too, but decided to keep it as is.
PostPosted: Fri Aug 29, 2014 3:15 pm  (#8)
Thanks Wallace for the link. Click the link below for it's Flickr (and while there, you can click the uber hirez result too). I vector resized the template in GIMP (easy to do for 2-color templates). :)
Phoenix Obsidian
https://www.flickr.com/photos/34520999@N05/15072990471/
PostPosted: Fri Aug 29, 2014 3:31 pm  (#9)
Looks good, Wallace. Only a few jaggies here and there. :smiley2
Pretty smooth, Lyle. :cool
PostPosted: Fri Aug 29, 2014 3:32 pm  (#10)
Thanks Tux; converting to vector before resizing is the secret. :)
PostPosted: Fri Aug 29, 2014 3:46 pm  (#11)
I just made that to tease you W, I do like yours better.
PostPosted: Fri Aug 29, 2014 3:48 pm  (#12)
Phoenix Obsidian
WoW Lyle that looks great! Really smooth like Tux says. :jumpclap
Thanks Tux. ;)
Why you... :hoh
PostPosted: Fri Aug 29, 2014 4:03 pm  (#13)
Yeah. I'd imagine that converting to a vector would smooth up the edges. Unfortunately, the original was a smallish .jpg, rather than a large png on a transparent background.
I did this with a smooth, solid color map. No vector convert.
PostPosted: Fri Aug 29, 2014 5:16 pm  (#14)
Nice! :jumpclap
PostPosted: Fri Aug 29, 2014 5:55 pm  (#15)
conbagui wrote:
Very nice Wallace, I like the 3d look.
Thanks Conbagui, I had fun making it. :bigthup
PostPosted: Fri Aug 29, 2014 6:41 pm  (#16)
Very nice Tux, I love the pinky purple with the gold colored woven background
PostPosted: Fri Aug 29, 2014 7:45 pm  (#17)
Nice result Tux; actually, for the conversion, it came out pretty clean. I first selected white, then inverted selection and then went selection to path to create the vector. I then cleared the image, created a transparent layer, resized the image (resizing a blank screen is easy; lol), and then did path to selection and filled with black. Very clean uprez. :)
PostPosted: Fri Aug 29, 2014 7:53 pm  (#18)
Attaching the svg vector (resized). Only thing I did before the resize this time which I did not do in my original is cleaned up the eye before the resize. :)
Phoenix_T.zip [5.71 KiB]
Downloaded 122 times
PostPosted: Fri Aug 29, 2014 8:25 pm  (#19)
Nice work on the phoenix Wallace.
PostPosted: Fri Aug 29, 2014 8:40 pm  (#20)
I did the same thing this time to get a larger and cleaner image.
Thanks He4rty! :bigthup
I had to make a nicer one though, or what I feel is a much better image.
And it's purplish too. :jumpclap
