It is currently Fri Nov 20, 2026 11:09 am
 Post subject: Re: Big Star (Which one you like better?)
PostPosted: Fri Sep 05, 2014 5:55 pm  (#1)
I like #1, for sure! The second one looks a little dirty like it was dropped in the mud imo...but that's just my opinion! xD
Nice work. :3
PostPosted: Sat Sep 06, 2014 2:50 am  (#2)
they both seem a little to sharp around the edge
PostPosted: Sat Sep 06, 2014 3:25 am  (#3)
Number one looks more plausible. I think the black spots are an issue with the second and against a darker base, some of the bright swirls look more artificial.
Still cool though :).
Margaret McGaffey Fisk
steampunk, fantasy, science fiction, and romance author
Tales to Tide You Over
PostPosted: Sat Sep 06, 2014 4:28 am  (#4)
I like the colors better in the first one. The second one is too dark in places to be a believable star which is a reactor for light and energy. Dark spots look kind of out of place because of that. I would even go as far as dodging in some white areas, maybe with a rendered cloud layer or something. Grae was spot on with the sharpness. You could benefit from a gaussian blur halo around the outside as well as a soft blur towards the edges. This will help it look dimensional too. You could also try to mess with the lens filter and bend the whole thing, or map to sphere before you overlay any of the swirls. That will keep your texture from looking like a cut out circle. Stars are tricky like that because you don't get to fake roundness with shadows, like for planets; you have to accomplish it with texture and perspective alone.
All in all though, I commend you for tackling something a little more complex like this. It's definitely a good direction to explore.
PostPosted: Sat Sep 06, 2014 8:22 am  (#5)
I like #1.
PostPosted: Sat Sep 06, 2014 9:23 am  (#6)
I like the first one. Much more dramatic.
PostPosted: Sat Sep 06, 2014 9:51 am  (#7)
I love the way you did the planets - with glowing atmosphere and all. Very realistic looking,
although in such close proximity to the star there would be no atmosphere left.
PostPosted: Sat Sep 06, 2014 8:35 pm  (#8)
I think the first one looks much more realistic.
