It is currently Thu Nov 19, 2026 9:41 pm
 Post subject: Gold Doves
PostPosted: Tue Apr 13, 2010 2:16 pm  (#1)
I made this gold set using a plain white dove
copied the dove on a transparent layer, filled it with gold gradient, put it through the bevel filter twice 5 then 7.
made the chain using circle ring brush#3 on a new transparent layer, filled it will gold, beveled #3
then shrank the doves down to earring size and duplicated. they were already beveled before shrinking.
Made the two o studs using the audi brush, filled with gold gradient beveled #2 or #3. all done on separate layers.
Then filled background with Maroon Satin...
Voila! nice jewelry set....
 Post subject: Re: Gold Doves
PostPosted: Tue Apr 13, 2010 2:58 pm  (#2)
Fantastic! Love the satin background, that always makes jewelry look extra nice!
PostPosted: Tue Apr 13, 2010 3:02 pm  (#3)
:ditto
Gorgeous!
PostPosted: Tue Apr 13, 2010 3:35 pm  (#4)
thanks gals...... :paint2
one more. This is a small chain I tried to make out of a square made with the paintbrush with a tit on the side. I then alternated it with one of Oregonians beads.
Notice on the gradient background the "O"'s beads take on the purple and pink of the gradient.
If the beads would turn it would have made a nice chain.Image
Anyway, the chain is called M_O.png......... Molly_OregonianImage
PostPosted: Sat Nov 05, 2016 11:56 am  (#5)
AWESOME!
Image ImageImage Image Image :clap
PostPosted: Sat Nov 05, 2016 2:55 pm  (#6)
Beautiful Molly, for both sets of jewelry. Where do we send our orders?
