It is currently Thu Nov 19, 2026 9:18 am
Post new topic Reply to topic  [ 66 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Graphic Boost Preset Gallery
PostPosted: Mon Feb 07, 2011 11:57 pm  (#1)
Ok finally i may connect ,
Graphic Boost can create very different effects, to illustrate some and offer some starting point to experiment i created some presets
i tested all with the same group of images, obviously what created as beaty retouch filter for Lions may have a devastating effect on a the smooth skin of a nice model , and vice versa
DARK DRAMA
Old Car
GRaphic Boost Preset _Dark Drama by PhotoComiX, on Flickr
From
No bad on the MEERKAT
before
Meerkat at North Carolina Zoo by jimbowen0306, on Flickr
after
Mixed result with a nice model...seen at original size the effect on the skin is devastating scaling down the image the effect soften
Original
Stay Golden by inorman88, on Flickr
After
here a different model and coreography
Before
Plaza de la Mercè, Barri Gòtic / Spain, Barcelona by flydime, on Flickr
Tested also on hinge-back shrimps
Original
the preset
{GB-Dark Drama}{Graphic_Boost}{gimp_boost1}{gimp_boost1}{1.9802}{1.36364}{0.727273}{16.8317}{1}{0.254545}{0.842178}{5.36364}{0}{2}{0.963636}{0}{0.536364}{0.818182}{1.54545}
 Post subject: Re: Graphic Boost Preset Gallery
PostPosted: Tue Feb 08, 2011 12:26 am  (#2)
WILDLIFE POETRY
gmic Graphic Boost test _wildlife poetry by PhotoComiX, on Flickr
Before
DSC00169-S.jpg by { pranav }, on Flickr
Before
IMG_1077 by Dey, on Flickr
A tip
all examples here were edited only with the preset
Anyway after running the preset you may try duplicate the layer and set the duplicate to multiply to boost contrast and obtain darker colors
{GB wildlife poetry}{Graphic_Boost}{gimp_boost1}{gimp_boost1}{1.9802}{1.36364}{0.727273}{16.8317}{1}{0.60396}{0.842178}{2.13636}{1}{4}{1}{1}{0.536364}{0.818182}{1.54545}
PostPosted: Tue Feb 08, 2011 12:29 am  (#3)
Congrats on getting your speed back PC. Like this preset and have used it more then a few times already. :)
PostPosted: Tue Feb 08, 2011 12:50 am  (#4)
Yes it is great to see you back PC!
Grabbed them both, thanks. :tyspin
How about Dark Drama Animal Poetry?
Dark Drama top layer set to overlay
Animal Poetry bottom layer
PostPosted: Tue Feb 08, 2011 1:03 am  (#5)
Thank not sure of what i already posted i started again here to post all
@ Rod
cool
here GB _ Skin Horrifier
The name came from the devastating effect he had on the skin of the first model, (not posted here) but that never happened again , at least not so dramaticallly
anyway use with care with close up expecially of woman...
[G'MIC] GB-Skin Horrifier ; -gimp_boost1 1.25,1.5,0.15,14,1,0.5,0.45,2.22727,1,0,1,0,0.5,0.45,0.78#7 by PhotoComiX, on Flickr
at original size you may see that the effect on the skin is no gentle as may seem looking the thumb below
[G'MIC] GB-Skin Horrifier ; -gimp_boost1 1.25,1.5,0.15,14,1,0.5,0.45,2.22727,1,0,1,0,0.5,0.45,0.78#6 by PhotoComiX, on Flickr
Unfortunaly the preset didn't pass well the the Presidential test
<a href="http://www.flickr.com/photos/photocomix-mandala/5426849101/" title="[G'MIC] GB-Skin Horrifier ; -gimp_boost1 1.25,1.5,0.15,14,1,0.5,0.45,2.22727,1,0,1,0,0.5,0.45,0.78#5 by PhotoComiX, on Flickr"><img src="http://farm6.static.flickr.com/5014/5426849101_3813486494.jpg" width="500" height="420" alt="[G'MIC] GB-Skin Horrifier ; -gimp_boost1 1.25,1.5,0.15,14,1,0.5,0.45,2.22727,1,0,1,0,0.5,0.45,0.78#5" /></a>
But on the other hand good result from hobos..
[G'MIC] GB-Skin Horrifier ; -gimp_boost1 1.25,1.5,0.15,14,1,0.5,0.45,2.22727,1,0,1,0,0.5,0.45,0.78#1 by PhotoComiX, on Flickr
....and Lions
[G'MIC] GB-Skin Horrifier ; -gimp_boost1 1.25,1.5,0.15,14,1,0.5,0.45,2.22727,1,0,1,0,0.5,0.45,0.78#2 by PhotoComiX, on Flickr
and is no bad for Indian hurban shoots...
[G'MIC] GB-Skin Horrifier ; -gimp_boost1 1.25,1.5,0.15,14,1,0.5,0.45,2.22727,1,0,1,0,0.5,0.45,0.78#4 by PhotoComiX, on Flickr
...old car
[G'MIC] GB-Skin Horrifier ; -gimp_boost1 1.25,1.5,0.15,14,1,0.5,0.45,2.22727,1,0,1,0,0.5,0.45,0.78#3 by PhotoComiX, on Flickr
no problem from hinge-back shrimp face's skin
[G'MIC] GB-Skin Horrifier ; -gimp_boost1 1.25,1.5,0.15,14,1,0.5,0.45,2.22727,1,0,1,0,0.5,0.45,0.78 by PhotoComiX, on Flickr
{GB-Skin Horrifier}{Graphic_Boost}{gimp_boost1}{gimp_boost1}{1.25}{1.5}{0.15}{14}{1}{0.5}{0.45}{2.22727}{1}{0}{1}{0}{0.5}{0.45}{0.78}
PostPosted: Tue Feb 08, 2011 4:03 am  (#6)
This is so neat and such fun.
Before
After
PostPosted: Tue Feb 08, 2011 6:22 am  (#7)
Hi PC,
This is the first time I saw graphic boost.
I searched but couldn't find anything on where to find the script.
I do have G'MIC installed but it doesn't have this.
Could you please post a link and instructions on how to install?
Many thanks in advance.
Gerard.
Edit: Found the tut by mahvin how to add scripts to G'MIC in ubuntu.
Although I use Gentoo Linux it's linux too.
Gimp-2.8.14
I use Linux only.
And Virtualbox with Win 7
PostPosted: Tue Feb 08, 2011 6:40 am  (#8)
gerard82. This may help until PC comes on line.
http://www.flickr.com/groups/gmic/discu ... 372068491/
PostPosted: Tue Feb 08, 2011 6:44 am  (#9)
@gerard82 - you may have to install GMIC 1.4.8
http://www.flickr.com/groups/gmic/discu ... 763559209/
@O - Wow look at the detail that came out in those bumblebee wings!
Very nice.
@PC - Can you possibly give a tutorial on saving presets in GMIC using the scripts made for it?
Thanks!
PostPosted: Tue Feb 08, 2011 6:56 am  (#10)
Graphic Boost should be in the last version of gmic (gmic has a new version almost any week...) anyway i posted the code also here viewtopic.php?f=9&t=981&start=0
about install new filter and preset is explaned here viewtopic.php?f=9&t=978&start=0
@ROD
sure !
PostPosted: Tue Feb 08, 2011 10:19 am  (#11)
Thanks all.
I d/led G'MIC-1.4.8.1 from Rod's link and compiled it.
I had to install "openVC" first before it wanted to install (dependency).
I installed it in the global Gimp plugin directory.
Anyway it works like a charm!
I am working on adding textures in Sculpture Generator.
I want to finish that first before exploring Graphic Boost.
Thanks again and long live Gimp Chat.
Gerard.
Gimp-2.8.14
I use Linux only.
PostPosted: Tue Feb 08, 2011 10:47 am  (#12)
Wildlife Poetry is suhweeeeeeeeeet!
My Sigs = My Photos
PostPosted: Tue Feb 08, 2011 2:33 pm  (#13)
:paint SOFT COLOR_BURN
the originals are always the same and are all in the first message.
No any other pre or post edit only the effect of the preset
[G'MIC] GB-soft Color burn ; -gimp_boost1 1.9802,2.9703,2.0198,16.8317,1,0.5,0.782178,2.22727,1,2,0.281818,1,0.5,0.628713,1.73267#1 by PhotoComiX, on Flickr
Close Up
notice t
[G'MIC] GB-soft Color burn ; -gimp_boost1 1.9802,2.9703,2.0198,16.8317,1,0.5,0.782178,2.22727,1,2,0.281818,1,0.5,0.628713,1.73267#6 by PhotoComiX, on Flickr
[G'MIC] GB-soft Color burn ; -gimp_boost1 1.9802,2.9703,2.0198,16.8317,1,0.5,0.782178,2.22727,1,2,0.281818,1,0.5,0.628713,1.73267#4 by PhotoComiX, on Flickr
[url=http://www.flickr.com/photos/photocomix-mandala/5428832530/][G'MIC] GB-soft Color burn ; -gimp_boost1 1.9802,2.9703,2.0198,16.8317,1,0.5,0.782178,2.22727,1,2,0.281818,1,0.5,0.62871
3,1.73267[/url] by PhotoComiX, on Flickr
[G'MIC] GB-soft Color burn ; -gimp_boost1 1.9802,2.9703,2.0198,16.8317,1,0.5,0.782178,2.22727,1,2,0.281818,1,0.5,0.628713,1.73267#3 by PhotoComiX, on Flickr
_____________________________________________________________
PRESET
{GB-soft Color burn}{Graphic_Boost}{gimp_boost1}{gimp_boost1}{1.9802}{2.9703}{2.0198}{16.8317}{1}{0.5}{0.782178}{2.22727}{1}{2}{0.281818}{1}{0.5}{0.628713}{1.73267}
[G'MIC] GB-soft Color burn ; -gimp_boost1 1.9802,2.9703,2.0198,16.8317,1,0.5,0.782178,2.22727,1,2,0.281818,1,0.5,0.628713,1.73267#7 by PhotoComiX, on Flickr
[G'MIC] GB-soft Color burn ; -gimp_boost1 1.9802,2.9703,2.0198,16.8317,1,0.5,0.782178,2.22727,1,2,0.281818,1,0.5,0.628713,1.73267#2 by PhotoComiX, on Flickr
:wh THE PRESET :wh
PostPosted: Wed Feb 09, 2011 4:51 am  (#14)
Yet another awesome preset PC! :)
Thanks for sharing it.
PostPosted: Wed Feb 09, 2011 3:48 pm  (#15)
Original image here.
PostPosted: Wed Feb 09, 2011 4:02 pm  (#16)
I like this, O. Good picture, too. Is it one of yours (or family's) or found on the internet?
PostPosted: Wed Feb 09, 2011 4:10 pm  (#17)
Found on Internet.
Trying to figure out where the Soft Color Burn preset is. It's either not showing up or hiding somewhere in gmic.
PostPosted: Wed Feb 09, 2011 4:36 pm  (#18)
Layers - Color Burn
PostPosted: Wed Feb 09, 2011 4:44 pm  (#19)
Thanks, mahv. I need a catalog with everything in gmic and the paths in it so I know where to look.
It did a really nice job on that '41 Chrysler. Original image here. It brought out the colors in it.
PostPosted: Wed Feb 09, 2011 4:51 pm  (#20)
It sure did, didn't it? I would recommend adding another layer of the original image and hard light mode to bring it back to a regular light. Burn tends to darken it, still looks nice though. Turn the hard light layer off after you add it, and you'll see the difference.
Scratch that. It brightened it too much. Bleh. It really looks fine as it is, I was just trying to find a way to bring out the car's detail in the middle of all that new color.
