It is currently Fri Nov 20, 2026 8:49 am
Post new topic Reply to topic  [ 98 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: A Plate?
PostPosted: Sat Oct 04, 2014 1:51 am  (#1)
Trying out a few things. Ended up with this.
 Post subject: Re: A Plate?
PostPosted: Sat Oct 04, 2014 3:28 am  (#2)
Yes it looks like a plate, sallyanne.
Is it made with the new frame-glass Plugin?
PostPosted: Sat Oct 04, 2014 5:52 am  (#3)
No. I could try that though. I would like to make a glass looking plate.
I did the original circle pattern in G'MIC, (pattern - circle art) then embossed the image, I added a layer and put a gold gradient blend on it. After that I reduced the opacity to let the pattern show through. Merged layer down. I cut out a circle from this using the ellipse select and pasted as a new image.
Keeping the selection of the circle I carved/chiseled the edge. Then I shrunk the selection 100 px and run chisel/carve for each ring.
I did change the settings somewhere but you can't notice. (I can't any how).
Hmmmmmm might try that glass plate now.
Same image done with glass frame - textured glass
PostPosted: Sat Oct 04, 2014 6:49 am  (#4)
Nice work. I love the spiral.
PostPosted: Sat Oct 04, 2014 7:15 am  (#5)
I made my circles with the ‘path shape creator’.
After that, shrunk the circle path of each layer with 100.
Made a golden gradient and lowered the opacity.
The largest path I stroked with a golden gradient and bumped it.
It’s only my version of your creative idea.
BTW I like your first version more than mine, sallyanne :) :bigthup
Edit: Forgot to mention, on every circle path I ran the frame-glass-effect script!
PostPosted: Sat Oct 04, 2014 8:16 am  (#6)
It's lovely Ella. :kpix
I am still playing around with the carve/chisel filter. I used both the glass frame and chisel and put my result in the glass frame thread
PostPosted: Sat Oct 04, 2014 10:38 am  (#7)
Sallyanne, your first one looks like a pottery plate to me. I like it.
@Ella: yours is like a metal plate that may have a bit of heat staining. Nice!!
PostPosted: Sat Oct 04, 2014 11:13 am  (#8)
@ sallyanne, thanks for the comment, playing around with different possibillities in Gimp is fun :)
@ Oregonian, you are right it looks like that!
PostPosted: Sat Oct 04, 2014 1:31 pm  (#9)
@Dinasset, I tried to make you a bowl of soup dinasset, but it turned into something else, haven't figured out what yet. :teeth
:roll: :roll: :pengy
PostPosted: Tue Oct 07, 2014 6:25 am  (#10)
I have no idea Molly why it got the ^ in the first ring from the edge. Maybe the selection followed some of the pattern? I'm sure the selection was a smooth circle.
By the way it does look like broth with a little bit of Chicken? in it.
PostPosted: Tue Oct 07, 2014 6:40 pm  (#11)
@sallyanne - it was seeing some of your posts that inspired me to join Gimp Chat and to try out the glass frame script in the first place! So whilst I am reasonably new to Gimp, I was following your posts on 'plates' this morning but I do not understand some of the techiniques you/others refer to like 'path shape creator' and bevel/chisel.
Even so I thought I would have a try at a glass plate using the glass frame effect script. It is attached below but I have no idea now what I actually did in the end to create it, as I accidentally closed off Gimp without saving the xcf file!!
File comment: Textured glass plate
PostPosted: Tue Oct 07, 2014 7:44 pm  (#12)
That came out great. It makes me think of glass. Good job. :hi5
PostPosted: Tue Oct 07, 2014 11:30 pm  (#13)
OK - because I love textured glass and the glass effect script, I tried another plate. This time I used a pattern of a rock face in the Katherine Gorge. The bevelling function still confuses me but trial and error and some extra touches produced the attached from the script, with separate iterations for plate centre and rim.
Thank you Sallyanne et al for providing inspiration and Oregonian for the kind words - being retired has some wonderful benefits!
File comment: Rock pattern glass plate
PostPosted: Wed Oct 08, 2014 2:56 am  (#14)
Great job.
I still have to learn how to use the bevel effect well. So I used instead the chisel/carve effect.
Ella used the Path shape creator. Someone here may be able to give you a link to it.It is a script. Makes quite a few shapes. Mine does 22
Here is one - the star...it does ellipses as well but I did this one with ellipse select.
PostPosted: Wed Oct 08, 2014 3:40 am  (#15)
Thanks Sallyanne. Well the adrenalin has been flowing today - so just one more glass plate, this time using a photo of my peaches and cream grevillea as a pattern. Whilst I am still not sure of how some things function, I now seeem to have a workflow for these particular items!
File comment: Grevillea glass plate
PostPosted: Wed Oct 08, 2014 4:05 am  (#16)
That makes a lovely plate :kpix
PostPosted: Wed Oct 08, 2014 4:50 am  (#17)
Here's my variation on a plate..
PostPosted: Wed Oct 08, 2014 5:15 am  (#18)
Very nice tux, is that from scratch? If so, you did an excellent job on the bevel and shadows.
PostPosted: Wed Oct 08, 2014 5:39 am  (#19)
Yes. The plate was done from scratch but BRL did most of the work on bevels and shadows. All I had to do was to provide a template for it to work with. I need to do a little more work though because It kinda looks more like the bottom of a plate than the top of the plate. I think the ridge needs to be more concave than convex.
Here's the plate template I have so far. Y'all are welcome to play around with it to see what you can come up with.
PostPosted: Wed Oct 08, 2014 5:46 am  (#20)
Thanks Tux. Mine ended up like a shuffleboard disk... :oops: All in the settings... right
