It is currently Fri Nov 20, 2026 11:08 am
 Post subject: First try using brushes.
PostPosted: Mon Oct 13, 2014 3:46 am  (#1)
Hello,
this is my first try at a using some more of the default tools in Gimp.
First is the image I began with that I downloaded from Public domain website of a girl meditating/thinking.Second is my the image I made using it.
I decided to put a pepper from the brushes into her hand as it looks nice/nature related.
Some think inside the box, others think outside the box.
I think, what box ~ why limit yourself.
 Post subject: Re: First try using brushes.
PostPosted: Mon Oct 13, 2014 7:40 am  (#2)
Hi bitsnpcs, Pretty good for first try! from animol
PostPosted: Mon Oct 13, 2014 7:11 pm  (#3)
Hello animol,
Thank You for your feedback :)
The overall idea was the girl is sitting underneath a tree, but the tree is off the right of the image and not visible as I cannot do the tree yet. This gives her shelter. The tree branches look the same perspective as her. The scenery I painted to look disjointed to her internal world, she is in her internal world and is daydreaming/meditating/pondering. Centre is some little stones/pebbles so she doesn't lose touch with the reality of the world. The flowers that are mauve are Thyme, the blue flowers it is Rosemary, I grow these herbs.
I enjoyed doing it a lot :) :gimp
PostPosted: Mon Oct 13, 2014 7:14 pm  (#4)
Not bad, things can only get better.
I wouldn't have had the guts to post my first attempt at something using Gimp.
My hat's off to ya. :bigthup
PostPosted: Mon Oct 13, 2014 7:43 pm  (#5)
Hello Wallace,
I thought it was important really as then members can see the level of my newbieness, I am grateful of the time they may use to answer a question I may ask, this way it allows members to determine the amount of time.
PostPosted: Mon Oct 13, 2014 8:42 pm  (#6)
The whole tree doesn't even need to be in the picture, as the leaves allude to it's presence. Very nice composition.
PostPosted: Mon Oct 13, 2014 10:11 pm  (#7)
Hello 2-ton,
Thank You for your feedback, this will help me with planning future ones :)
