It is currently Fri Nov 20, 2026 10:01 am
 Post subject: Piggy too.
PostPosted: Thu Oct 16, 2014 3:18 pm  (#1)
I do piggy's too Sallyanne. lol
Like your piggy better though; have a link to the template?
Got the image from a zip collection at the Open Clip-art project. :)
 Post subject: Re: Piggy too.
PostPosted: Fri Oct 17, 2014 12:46 am  (#2)
When i get back online I will send it. Assuming you just meant the picture I used. It is just a black and white clipart piece. Not sure what settings I used.
You did really well with this one though.
PostPosted: Fri Oct 17, 2014 7:36 am  (#3)
The clip-art Sallyanne. :)
PostPosted: Mon Oct 20, 2014 5:25 am  (#4)
This is the template I used for a pig although I just realized the file name says panda??
PostPosted: Mon Oct 20, 2014 3:59 pm  (#5)
Thanks Sallyanne. :)
PostPosted: Mon Oct 20, 2014 5:22 pm  (#6)
Here's a poor attempt at cleanup using Autotrace centerline option followed by some manual cleanup steps. :)
 Post subject: Spider Wants some Pork.
PostPosted: Mon Oct 20, 2014 9:12 pm  (#7)
lol
Well, it is only a week or two away from Halloween. :)
https://www.flickr.com/photos/34520999@ ... 2/sizes/o/
PostPosted: Tue Oct 21, 2014 1:37 am  (#8)
very nice spider webs. Thanks for cleaning the clip art up, downloaded your fresh pic of it. I found the clip art site you mentioned but couldn't find any zip files of anything so just spent an hour downloading different pics from there. :tyspin
PostPosted: Tue Oct 21, 2014 4:19 am  (#9)
Did you happen to use the 'skeleton' preset in G'MIC? I was only able to get part of the same effect. My centre stayed blank.
You did really well Lyle. I'll have to try it again later with some other things as well.
PostPosted: Tue Oct 21, 2014 11:31 am  (#10)
Yes; it is skeleton Sallyanne. The open clipart site use to host some huge zip files of all their collections; they may have stopped doing so. :)
