It is currently Fri Nov 20, 2026 10:05 am
 Post subject: BRL, butterflies and serendipity
PostPosted: Sun Dec 07, 2014 1:39 am  (#1)
I have just sat through the noisiest, flashiest, wettest thunderstorm ever trying to work out what all the different BRL options can do. Yes Wallace I was using butterflies and it was possibly going to turn into a mandala!
But it was difficult to concentrate and just as I was applying BRL to the last set of butterflies, there was an almighty flash right through the room followed immediately by an almighty crash of thunder. BRL then took ages to process.
It turned out that I had, once again, not got my selections right ... but no worries BRL produced not just the butterflies (plastic blow up ones my wife reckons) but a magnificent frame too. Who needs frame factory now!!
 Post subject: Re: BRL, butterflies and serendipity
PostPosted: Sun Dec 07, 2014 10:35 am  (#2)
:wow
Those are some wild results OMG. Image
PostPosted: Sun Dec 07, 2014 3:02 pm  (#3)
I like all the cool colors, oldmangrumpy. :2thup
