It is currently Fri Nov 20, 2026 10:01 am
 Post subject: Voronoi stipple approach to mosaic.
PostPosted: Fri Dec 19, 2014 1:59 am  (#1)
Started off using voronoi stipple and then fed the dots through G'MIC to create the panels. Still not as aesthetic to me as Dr. di Blasi's approach. :)
ref: http://www.fontplay.com/freephotos/seve ... 806-03.jpg
 Post subject: Re: Voronoi stipple approach to mosaic.
PostPosted: Fri Dec 19, 2014 2:16 am  (#2)
Very impressive Lyle. :bigthup
PostPosted: Fri Dec 19, 2014 2:31 am  (#3)
when using Dr. di Blasi's program the bricks were always square, and I couldn't work out how to save, did you do a tute anywhere
PostPosted: Fri Dec 19, 2014 2:40 am  (#4)
@Graechan
start mosaic.jar
select OPUS MUSIVUM + DIR.GUIDELINES
open your image (not too big...)
run CREATE
you get something like this
click on save
select the folder where to put in the outcome
save
PostPosted: Fri Dec 19, 2014 3:13 am  (#5)
Thanks dinasset that worked :bigthup
PostPosted: Fri Dec 19, 2014 3:20 am  (#6)
you're welcome
(you always help me: did you see my last update of my woodcut script? it includes your requirement of:
- having rescale optional
- make seamless applied to the pattern)
PostPosted: Fri Dec 19, 2014 3:23 am  (#7)
to me it's an excellent result (and w/o size limitations, as I can see)
what did you do exactly?
PostPosted: Fri Dec 19, 2014 10:12 am  (#8)
After running Voronoi Stipple (both image and negative of image into the program and blended the Dots in GIMP), I ran G'MIC's Skeleton preset (thinning; yes it's slow) followed by GIMP's Dilate filter to widen the outlines. I then inverted and ran G'MIC blend>shape Average (under customer Testing>lylejk>) with transparency. I then commenced to add dimension using G'MIC's Local Orientation preset (under Contours) to taste. :)
PostPosted: Fri Dec 19, 2014 10:15 am  (#9)
Glad you workedit out Graechan. The trick I use to further process the result is, after running the initial target image (gives you a colored result of course), I use the same parameters but change the image to a solid white one. This then gives you all white blocks. I then feed the result into GIMP, resize, then Autoequalize the image (makes the line darker). I then run G'MIC's Lylejk Stencil to clean the edges before using Blend (Shape Average) under Testing>Lylejk
PostPosted: Fri Dec 19, 2014 10:49 am  (#10)
Here's another one; re-thought how to create the initial stippler mask in order to give more varying sized tiles. :)
ref: http://www.fontplay.com/freephotos/seve ... 406-03.jpg
PostPosted: Fri Dec 19, 2014 12:35 pm  (#11)
hehehe, Lyle, thanks, but I'm still on your first step (my fault I didn't ask explicitely):
what is Voronoi Stipple?
another program? downloadable? or...
PostPosted: Fri Dec 19, 2014 12:42 pm  (#12)
Background (long winded thread): viewtopic.php?f=28&t=613&hilit=Voronoi+Stipple
Link to program: http://www.saliences.com/projects/npr/s ... index.html
PostPosted: Fri Dec 19, 2014 1:30 pm  (#13)
This time I used Amphisoft's Xylograph filter (PS filter ran using Shellout) to create the Voronoi target mask. :)
ref: http://www.fontplay.com/freephotos/seve ... 506-09.jpg
https://www.flickr.com/photos/34520999@ ... 1/sizes/o/
PostPosted: Fri Dec 19, 2014 1:52 pm  (#14)
Background (long winded thread): http://www.gimpchat.com/viewtopic.php?f ... oi+Stipple
thanks a lot, Lyle!
PostPosted: Fri Dec 19, 2014 2:36 pm  (#15)
at least, I got something....horrible, but still "something"...
PostPosted: Fri Dec 19, 2014 4:50 pm  (#16)
This look like fun, but I wouldn't know where to begin.
PostPosted: Fri Dec 19, 2014 4:59 pm  (#17)
Be sure to run auto-equalize before you use Lylejk Stencil to clean up the result dinasset. Still, you got the flow right, so, now you can make the tut. My tut days are over. lol
PostPosted: Fri Dec 19, 2014 5:17 pm  (#18)
So you're passing the buck... :hehe
PostPosted: Fri Dec 19, 2014 5:20 pm  (#19)
Yup. lolol
PostPosted: Fri Dec 19, 2014 5:21 pm  (#20)
Yup. lolol
Why you... :hehe
