It is currently Fri Nov 20, 2026 10:03 am
 Post subject: Dream multifrac views.
PostPosted: Sun Dec 21, 2014 6:37 am  (#1)
View fractals as a relief map.
What do you need ?
Gimp and G'mic plugin
First create a new blank image size 800*600.
Make a radial gradient black center to white around.
duplicate layer and name the layer as fracta
fractalize layer fracta
duplicate layer fracta and name the new as smooth
dream smoothing on layer smooth set on mode multiply
duplicate fracta rename this new layer as desaturate
desaturate this layer option luminosity
duplicate desaturate layer and name new layer as bump map
filter - mapping - bump map with image . (i don't have english version not sure it's this name)
parameters sinusoidal - azimut 135-elevation 30- depth 14
Now as an option :
duplicate layer bum map and name new layer as raindrops
filter raindrops on this layer
Add a blank layer mask on it
Try to remove raindrops on higher relief with a black brush
Apply mask when you're satisfied
Enjoy Gimp and G'mic filters !
Fran6
 Post subject: Re: Dream multifrac views.
PostPosted: Sun Dec 21, 2014 9:28 am  (#2)
Francis,
a couple of examples, taking hint from your post
steps:
- gimp: gradient BW (one as you said, the other one inverted)
- gmic: fractalize
- gmic: boost chromaticity
- gmic: graphic boost
- gimp: emboss
personally I don't liker too much dream smoothing (which is very much appreciated -I know- by a lot of people)
PostPosted: Sun Dec 21, 2014 12:54 pm  (#3)
Nice dinasset, it's a more colored method. You have punched the palette. My idea was to preserve the palette of the fractalize script in order to have a map resemblance. Your planet is much more colorful :mrgreen:
PostPosted: Sun Dec 21, 2014 9:54 pm  (#4)
I have not played with fractals much yet, so I thought I would try this too. But I obviously made a mistake somewhere, so then I just decided to BRL the resulting modified fractal.
I will though have another try at both of these prescribed 'fractal relief' approaches later. Thanks for this info Fran6 and Dinasset.
EDIT ... tried again with your approach Fran6 and a much better result this time which I really like, so thank you again ...
PostPosted: Mon Dec 22, 2014 12:25 am  (#5)
Well done oldmangrumpy, your work is really nice. The BRL method is cool and seems to be promising as I saw in Wallace's topic.
One word on your second output. The relief effect is good.
It's often difficult to choose colors for a relief. For example, white seems to be a very good solution for mountains pixels. But someone else could prefer a different choice in order to use white for another thing.
As to me a good way to make a choice would be a smart palette tool.
PostPosted: Mon Dec 22, 2014 4:09 am  (#6)
I like them all! Fractals are cool.
Good job everyone :jumpclap :bigthup
PostPosted: Mon Dec 22, 2014 5:30 am  (#7)
tried 1.
PostPosted: Mon Dec 22, 2014 5:51 am  (#8)
Well done sallyanne ! It appears to me as an organic thing. Amazing one !
PostPosted: Mon Dec 22, 2014 5:55 pm  (#9)
@Fran6 - Je suis totalement surpris par les différents résultats qui peuvent être obtenus de cette merveilleuse technique ; je vous remercie beaucoup!
I have been experimenting this morning with various different tweaks - and being still a recent starter with GIMP I am just amazed at the differing possible outcomes.
Merci encore!!
PostPosted: Tue Dec 23, 2014 12:51 am  (#10)
Sally, OMG, very nice outcomes!
PostPosted: Tue Dec 23, 2014 1:20 am  (#11)
Wow - for some time I have been 'hooked' on Wallace's BRL thread and Dinasset's wood-carve script thread; now I am hooked on your fractal thread Fran6 - two more attempts ... endless possibilities!
PostPosted: Tue Dec 23, 2014 1:57 am  (#12)
@Oldmangrumpy You've done excellent outcomes !
if you want a more extreme experience with fractals, i suggest you have a look on this link :
http://www.apophysis.org/downloads.html
Hope you'll enjoy !
PostPosted: Wed Dec 24, 2014 4:26 am  (#13)
Another one with some modifications.
Used relief filter
Added some colors with a layer in mode superposition.
Still far from perfect but i like new colors around the center.
PostPosted: Wed Dec 24, 2014 5:26 am  (#14)
Another good result Fran6 - you really have me 'chasing my tail' right now, I just cannot stop creating fractals. Its particularly interesting to see what a few tweaks can do also to the initial result.
Thank you again for initially providing the tut on how to create these types of images. Merry Xmas.
PostPosted: Wed Dec 24, 2014 10:01 am  (#15)
OMG, your outcomes are wonderful! Merry Chistmas to you!
PostPosted: Thu Dec 25, 2014 7:56 pm  (#16)
@Fran6 - I took Xmas day off from exploring GIMP and your approach to fractals, but today the more I explore/play with differing initial image setups, the more excited I am getting about this method and the potential outcomes!
For example ...
PostPosted: Thu Dec 25, 2014 9:24 pm  (#17)
For example ...
And you said that I never sleep, on the contrary OMG.
PostPosted: Fri Dec 26, 2014 6:18 am  (#18)
@Wallace - yes I have been eating, drinking and sleeping GIMP for 3 months now; a nourishing diet and a great lifestyle for us retirees!
@Fran6 - more explorations extending the technique with multiple selection based fractals merged for the final images.
PostPosted: Fri Dec 26, 2014 7:06 am  (#19)
Very nice outcomes Oldmangrumpy ! Now it's time for you to explain us how you do this :mrgreen:
Btw it's the first time I can see a graphic fractals addiction :coolthup
PostPosted: Wed Dec 31, 2014 12:27 am  (#20)
@Fran6 - yes I am still addicted, learning and trying to extend my capabilities with all these fabulous tools to use. Here are a few more of the many I have created over the last few days, all initially based on your approach, then added to or tweaked a bit!! You wanted me to explain what I do with them so here goes.
In 'southpole' I re-bumped the fractal outcome with the original blend image I used to create the fractal relief, then I over layed that original image too.
In wine & cheese I used line art images and created fractals for each selection plus the background and merged the lot.
For this one I used a lion image, did separate fractals for it and the background then overlayed the lion fractal with the original line art image to which I applied a Samj (GMIC) texture.
Hope you like them.
