It is currently Fri Nov 20, 2026 8:51 am
 Post subject: Re: Gimp Clock
PostPosted: Thu Jan 15, 2015 3:41 am  (#1)
I think you need to consider the time: http://petapixel.com/2013/06/27/why-pho ... time-1010/
or if you prefer video:
Kevin
PostPosted: Thu Jan 15, 2015 4:28 am  (#2)
fantastically implemented Conbagui. :clap
PostPosted: Thu Jan 15, 2015 7:18 am  (#3)
conbagui wrote:
Changing pace, How do you like this one?
Can i get the XCF for this so i can set it up in Clocx? :)
PostPosted: Thu Jan 15, 2015 12:12 pm  (#4)
Nice work Conbagui, I love the colors you used. :bigthup
@ Rod...I'd like to have this clock for Clocx too Rod. Will you post the files for it if you ever get the xcf?
PostPosted: Thu Jan 15, 2015 1:30 pm  (#5)
Most certainly.
I'm not home right now, but as soon I get home this evening I will post the XCF. Thank you for your interest
Thanks! :)
PostPosted: Thu Jan 15, 2015 10:08 pm  (#6)
Really nice job.
PostPosted: Fri Jan 16, 2015 6:12 am  (#7)
Cool :bigthup
PostPosted: Fri Jan 16, 2015 6:28 am  (#8)
conbagui wrote:
Look at my first post and you will have it. :hehe
Thanks conbagui! :)
PostPosted: Fri Jan 16, 2015 9:37 am  (#9)
Ok here is a screenshot and the zip is attached.
The zip includes the clock image and the ini file. Place both in your Clocx presets folder and right click your clock and select options. Click the Appearance tab and select these options.
Click ok. The clock should be on your desktop and you can now move it wherever you wish. Sorry it can get no smaller. :)
If you open the image in GIMP or another image editor BEFORE you place it in the preset folder and re size it (smaller) you can then save it to Clocx/presets folder and it will be smaller in Clocx.
Enjoy! :bigthup
WITHOUT hand and hour images-
GimpChatClock.zip [730.02 KiB]
Downloaded 236 times
Version two with hand and hour images-
GimpChatClock-v2.zip [727.83 KiB]
Downloaded 235 times
Example image-
PostPosted: Fri Jan 16, 2015 2:42 pm  (#10)
bump. :)
PostPosted: Fri Jan 16, 2015 3:32 pm  (#11)
Enjoy! :bigthup
GimpChatClock.zip
I was not able to get the hour and minute hand images to work. They have to be saved as a hpng (whatever that is). Seems to be some kind of Adobe Illustrator file.
Thanks for putting the Gimp Chat clock for Clocx together Rod and thanks for creating it Conbagui. :bigthup
PostPosted: Fri Jan 16, 2015 10:33 pm  (#12)
conbagui wrote:
Good work Rod. :clap Now, How can I replace the Hand on the clocx?
We would need to have a separate png images, (with a transparent background) for each of the clock hands that you used in your Gimp Clock image.
PostPosted: Fri Jan 16, 2015 10:59 pm  (#13)
Not sure what all this 'clocx' stuff is about, but your apparent issues with 'clock hands' reminded me of some aboriginal stories I heard about a 'timeless land' from an old aboriginal elder at Uluru ... so
Hope you do not mind me posting it in this thread! :)
PostPosted: Sat Jan 17, 2015 12:19 am  (#14)
I am still trying to figure that out. All the hands have a HPNG extension. It is some kind of Illustrator file. Does GIMP save in the hpng extension i wonder?
PostPosted: Sat Jan 17, 2015 12:44 am  (#15)
Not that I know of, but maybe Conbagui has the answer to that question.
PostPosted: Sat Jan 17, 2015 1:34 am  (#16)
No what i mean is any hand image used in Clocx, Clocx needs it to be a hpng extension for some odd reason.If i try to save the images as that extension in the presets folder they don't work. If you open one of those that does in notepad ++ you will see this. :)
‰PNG
IHDR   µ
›>   tEXtSoftware Adobe ImageReadyqÉe<  "iTXtXML:com.adobe.xmp     <?xpacket begin="" id="W5M0MpCehiHzreSzNTczkc9d"?> <x:xmpmeta xmlns:x="adobe:ns:meta/" x:xmptk="Adobe XMP Core 5.0-c061 64.140949, 2010/12/07-10:57:01        "> <rdf:RDF xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"> <rdf:Description rdf:about="" xmlns:xmp="http://ns.adobe.com/xap/1.0/" xmlns:xmpMM="http://ns.adobe.com/xap/1.0/mm/" xmlns:stRef="http://ns.adobe.com/xap/1.0/sType/ResourceRef#" xmp:CreatorTool="Adobe Photoshop CS5.1 Windows" xmpMM:InstanceID="xmp.iid:D3C59E439F2011E18651C5CDA301D5A0" xmpMM:DocumentID="xmp.did:D3C59E449F2011E18651C5CDA301D5A0"> <xmpMM:DerivedFrom stRef:instanceID="xmp.iid:D3C59E419F2011E18651C5CDA301D5A0" stRef:documentID="xmp.did:D3C59E429F2011E18651C5CDA301D5A0"/> </rdf:Description> </rdf:RDF> </x:xmpmeta> <?xpacket end="r"?>FÌ   ™PLTE   333fff         {{{äääüüüBBBHHHÀÀÀùùù¢¢¢ÏÏÏ„„„???TTT'''NNN```ºººŸŸŸççç xxxuuucccØØØ“““ÒÒÒ---ŠŠŠ¥¥¥(((aaaEEE999$$$‡‡‡±±±áááKKK000111ÿÿÿ„Nˆ   3tRNSÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ qž½Ž   ÖIDATxÚÔØ·‚P…áCÎ@PÌ9Ç÷8‘Âaä2:6Üó×_Á,»àÁ~zjÜî^¡)öÄàQ·l¼$jå´€Aí…øH'P÷PÉ—^íWÑp\ÉÕý@È”[=„°•Ôjs.V[Í«½£¥Ô´£Ñ¹)º…ú²N¹ÚeC#ÊÕ)ZËÕS:õîõ^gdèô˜|I¦Ö×͐ÚXKã뼞I;¯ÿø6Œ{È^ò=D¼ó%Œûõà–‰o™Êݘ²ÜèÛҍ~¦ú²€Ãõ?D¾ž ï"Œ:÷í    IEND®B`‚
Hence the reason i believe it's an Adobe imageready file extension.
I have Imageready and Photoshop so i will try and see what i can do. :)
PostPosted: Sat Jan 17, 2015 1:49 am  (#17)
‰PNG
IHDR   µ
I've always used png images and never had issues with any of the clocks I've made. This is the first time I've heard of this.
PostPosted: Sat Jan 17, 2015 1:53 am  (#18)
‰PNG
IHDR   µ
It seems the clock png images themselves work fine, but all the hand images are that funny extension. :)
How did you get your custom hands to work for your clocks in the ini file?
PostPosted: Sat Jan 17, 2015 3:42 am  (#19)
I used existing ini files and edited them accordingly. All the clocks I've made have custom hands that are png images I made with Gimp. The clocks I've made so far all work and all I use is png images.
I attached a zip file with 2 Spawn clocks I made, with all the png images and ini files to go with them.
Spawn ClocX Clock By Wallace.zip [404.34 KiB]
Downloaded 155 times
PostPosted: Sat Jan 17, 2015 6:19 am  (#20)
sexy looking clock Wallace. nice job
