It is currently Fri Nov 20, 2026 8:50 am
 Post subject: The Goddess.
PostPosted: Sat Jan 17, 2015 8:11 pm  (#1)
This one took me almost an hour; I'm a filter guy and yes, I used way too many filters, but then, I had to do a lot of interactions (hate that) that ended up taking me much longer then I wished. Here's the result. :)
ref: http://kayladavion.deviantart.com/art/Goddess-of-Wind-352453681
https://www.flickr.com/photos/34520999@N05/16115783440/sizes/o/
 Post subject: Re: The Goddess.
PostPosted: Sat Jan 17, 2015 8:25 pm  (#2)
That's real nice Lyle. :bigthup
PostPosted: Sat Jan 17, 2015 8:30 pm  (#3)
Almost an hour ?!!!
I could spend weeks and not get a result like that!
Are you going to give us any hints?
PostPosted: Sat Jan 17, 2015 8:42 pm  (#4)
The results are well worth your hour! It's lovely.
PostPosted: Sat Jan 17, 2015 8:43 pm  (#5)
Maybe a BOM list of programs used jon. lol
G'MIC (Bilateral preset will be your friend; also added some of the subtle glow using a low opacity layer of Rodilius), Paint Engine (still works via PSPI), but then a lot of help from PostworkShop Pro (yes; cheat I know; lol). All above not necessarily in chronological order not to mention a check of a lot of layer property blends w/ cloning. Almost forgot; I created a square selection and copied it; then I pasted it into another edit and ran Darla's Amazing Circle preset to create the Orb. I then added some additional glaze steps (G'MIC's Local Orientation among a few other things) and added the Starburst using Supernova. :)
And you just ninga'd me 2-ton; thanks for your comments too. :ninja
PostPosted: Sat Jan 17, 2015 10:35 pm  (#6)
lol; thanks conbagui. Yeah; have to, every so often, deviate from my filter craze and do something that filters alone won't do. I still try to find ways to get the computer to do it all, but do all the hard work is good too (except the cloning; jeeze; wish that could be automated too; lol). :)
PostPosted: Sun Jan 18, 2015 12:15 am  (#7)
Nice work Lyle.
PostPosted: Sun Jan 18, 2015 12:22 am  (#8)
Thanks he4rty; you are right about work and, for a no apologies for being one filter guy, it was more then I wanted it to be. lolol
PostPosted: Sun Jan 18, 2015 12:41 am  (#9)
Good looking :bigthup
PostPosted: Sun Jan 18, 2015 1:06 am  (#10)
Thanks Sallyanne; appreciate the fav at Flickr too. :)
PostPosted: Sun Jan 18, 2015 1:22 am  (#11)
Lyle, that is awesome! very artistic particularly the veil texture. Congrats! :clap :paint
PostPosted: Sun Jan 18, 2015 3:36 am  (#12)
Nicely done Lyle. Did you use the soap bubble filter also?
PostPosted: Sun Jan 18, 2015 7:55 am  (#13)
No; the glow had a lot of help from Rodilius followed by Bilat preset to clean up the threads. The clouds was pure brush work. I like cloud brushes. lol
PostPosted: Sun Jan 18, 2015 7:56 am  (#14)
Appreciate the comments Issabella. :)
PostPosted: Sun Jan 18, 2015 9:41 am  (#15)
She's beautiful, Lyle. Very nice work! :yes
PostPosted: Sun Jan 18, 2015 10:20 am  (#16)
WOW, that doesn't look like the stuff you usually do Lyle. You should do more of these, that is beautiful.
PostPosted: Sun Jan 18, 2015 12:32 pm  (#17)
I have to fully agree with Molly.
It's a so wonderful piece of photo manipulation, that you are wormly invited to continue on this way!!!
Congratulations Lyle!
(looking at the source, I saw there a lot of nice photos to use as a base for photo manipulation, I just took one and transformed into an Aquarel -it's my current obsession-....)
PostPosted: Sun Jan 18, 2015 1:13 pm  (#18)
Thanks Molly; thanks Dinasset. As for doing more of these, forget about it; I'm a filter guy. Once, every so often, I have to prove to myself that I still know my filters and how to use clone/heal brush. lolol
Way too lazy to do these often, but Kayla definitely motivated me. She has some good stock to play with for sure Dinasset. :)
