It is currently Thu Nov 19, 2026 9:21 am
 Post subject: Do you want test ?
PostPosted: Wed Feb 23, 2011 3:07 pm  (#1)
i was messing with the code of a gmic filter i did but something weird happened
Obviously i did some errors but the result is somehow interesting, the filter make apparently most of the image transparent but preserve the highlight and light color as yellow and for misterious reason even the red
obviously may be easily adapted to do the contary, preserve black and i suppose the green and turn the rest semitransparent
Apparently:
just add a black layer under and you will see something close to the original but with stretched contrast except for highlight..and replacing the black BG with a dark optical pattern result become even more interesting
ORIGINAL
Filter Effect (with under the gmic layer a black layer as BG)
Now...Replacing the black layer with a pattern
Or as bg layer may be used a dotted version of the original...
or simply as below a more psichedelic pattern
The problem is that i don't know yet why that happens, still that semitransparent layer seems to have a lot of possible use
so i zipped the xcf file with the code i used
Mean that now the controls do not work as intended even if somehow they change the final result
CODE HERE download/file.php?id=1455
 Post subject: Re: Do you want test ?
PostPosted: Wed Feb 23, 2011 3:32 pm  (#2)
PC:
Why not make two versions and name them according to their output? I would clearly love this particular option, even though its an error, plus to see what your intended code should have resulted in.
PostPosted: Wed Feb 23, 2011 3:34 pm  (#3)
here with a different pattern
i must run to do something now, i will be back soon with the zip.
Mahvin
i will add the code in the zip...but i must run now
PostPosted: Wed Feb 23, 2011 3:42 pm  (#4)
Now that looks psychedelically funky PC. lol
PostPosted: Wed Feb 23, 2011 4:04 pm  (#5)
Awesome results!
PostPosted: Wed Feb 23, 2011 4:36 pm  (#6)
I like the result! Even mistakes can be a good thing!
My Sigs = My Photos
PostPosted: Wed Feb 23, 2011 6:01 pm  (#7)
I LOVE it. Awesome mistake. It looks so funky and psychedelic.
PostPosted: Wed Feb 23, 2011 6:05 pm  (#8)
ok for the attachment limits i have to use 7zip instead then simple zip
swissmask.7z [6.74 MiB]
Downloaded 267 times
different settings (mainly the checkboxes) will change something but not much...remember to see the result at first on a solid black BG
@ O
the pscichedelic effect come from the BG layer that is seen trought the transparency
For the bg i just filled the BG layer with BW lines, then i edited the lines with fractal trace
PostPosted: Wed Feb 23, 2011 8:48 pm  (#9)
Thanks PC - awesome mistake you made there :lol
Keep it up! I love those results.They would make great posters.
PostPosted: Thu Feb 24, 2011 3:38 am  (#10)
Former Member
I like how the color correction on the second one!
PostPosted: Sat Feb 26, 2011 12:10 pm  (#11)
I was very lazy to see what the filter does should be sufficent use GMIC in verbose mode
Going to do now...
Still i am confused if seen on a white BG the result looks as crap
ORIGINAL
Filter + White BG
BUT on a black BG looks really diiferent ,as the original with a strected contrast, but with highlight protected
that allow the psichedelic effect i show before by replacing the black BG with a pattern
But also something else ...here i run the filter once, duplicated the result, changed the mode in Multiply
(top dup) and hard light (dup below) using the original as BG
but still i have not really a clear idea on how to use it, except to create sort of mask or psichedelic effect
PostPosted: Sat Feb 26, 2011 9:52 pm  (#12)
One thing comes to mind for a good application of this filter would be blending two images together in parts. Like for instance, take one object of an image and transfer it to a second image and blend. I have yet to experiment with the idea, but it seems at least mathematically, it would be a good mix.
PostPosted: Sun Feb 27, 2011 8:57 am  (#13)
I had a picture taken of me in our backyard way up in a tree.
I used the weird FX script, and a gradient bg.
PostPosted: Sun Feb 27, 2011 8:58 am  (#14)
I had one image looking like i was actually crawling around in someones veins.That was interesting.
Layer modes rock. :)
PostPosted: Sun Feb 27, 2011 10:06 am  (#15)
you have nice big trees in your backyard !
i like your manip
PostPosted: Mon Feb 28, 2011 11:15 am  (#16)
well for a confront a edited the original of the same image with one of my Graphic Novel preset,( Dark Outliner not sure if i posted here), no any other changes( no selection layermask etc) only the preset
then i place on top the last i show in color mode
PostPosted: Mon Feb 28, 2011 2:26 pm  (#17)
Wow so much difference in the color saturation.
PostPosted: Mon Feb 28, 2011 11:06 pm  (#18)
back to the weird semitransparency
here i replaced the black BG with my last pattern
