It is currently Fri Nov 20, 2026 7:47 am
 Post subject: Greeting Cards
PostPosted: Thu Mar 05, 2015 11:14 am  (#1)
I have been given the opportunity to create and sell greeting cards. I would like some honest feed back about these before I begin working on the inside greetings.
 Post subject: Re: Greeting Cards
PostPosted: Thu Mar 05, 2015 11:38 am  (#2)
very very nice!
if I should say a thing, just add a little bit more contrast ("body") to the pearls and to the lace, on the third one
PostPosted: Thu Mar 05, 2015 1:06 pm  (#3)
PostPosted: Thu Mar 05, 2015 2:06 pm  (#4)
The cards are looking good jeanniem.
Here's some worthy commercial printing info on setup and document area, bleeds and safety margins.
Two work flows to consider using guides; single face template with layers (easiest) and full template showing all sides.
I've attached a quick full template for perspective (US letter, guides might need adjustment).
If you use a single face template (w/layers & guides)
Gimp layer order (top down): Inside Right (rotate 180°), back, Inside Left (rotate 180°), Front.
Assemble with G'MIC, Arrays & tiles | Montage
Input / Output: All
Montage type: Auto
Merge mode: Scaled
[0] inside right, [1] back, [2] inside left, [3] front
Have fun! :bigthup
greeting-card-template.xcf.bz2 [36.45 KiB]
Downloaded 123 times
PostPosted: Thu Mar 05, 2015 2:33 pm  (#5)
Thank you all, your opinions and advice are most appreciated!
PostPosted: Thu Mar 05, 2015 2:35 pm  (#6)
Very nice. They all have a happy, warm feeling.
I do have a technical quibble on the first, music themed card. The jagged edges in the musical notes and the curve jars. You've minimized the issue on the others. Perhaps work oversize, if you can, and reduce. Consider rendering from SVG or other vector format.
Take care,
Garry
PostPosted: Sun Mar 08, 2015 10:43 pm  (#7)
I like those cards, they're cute. :3 :D
