It is currently Fri Nov 20, 2026 6:24 am
Post new topic Reply to topic  [ 49 posts ]  Go to page 1, 2, 3  Next
 Post subject: Engrave.
PostPosted: Fri Mar 13, 2015 9:47 am  (#1)
First of all, my apologies to grosood; should have started another thread then taking away from his fantastic one. Anyway, just wanted to share a result using David's new engrave preset. I can see book publisher's wanting to use this one David. :)
ref: http://www.fontplay.com/freephotos/seve ... 606-14.jpg
 Post subject: Re: Engrave.
PostPosted: Fri Mar 13, 2015 12:37 pm  (#2)
Great Lyle !
Just to remind the reader : there is a new G'MIC filter Black & White / Engrave available to play with :
And it is definitely nice to create drawings from images too. Here is my last attempts with my daughter and me):
PostPosted: Fri Mar 13, 2015 12:55 pm  (#3)
Another example, with the filter Engrave used two times, then mixed, with a color layer :
PostPosted: Fri Mar 13, 2015 1:30 pm  (#4)
Again, do appreciate you doing this one David. :)
PostPosted: Fri Mar 13, 2015 2:44 pm  (#5)
I'm playing more and more with this filter, and already I think I've a new pipeline I will be able to code as a new filter.
This is the kind of results I get :
I'm just a bit afraid about the amount of parameters to set in order to get the desired result.
I'm trying to figure out how to estimate them automatically, but this is not so easy.
PostPosted: Fri Mar 13, 2015 2:48 pm  (#6)
Blend a little half-tone dithering to this would make possibly a comic like result or even a Lichtenstein. :)
PostPosted: Fri Mar 13, 2015 3:17 pm  (#7)
with a totally different approach, tried your filter, David, using the parameter Perturbations set to 150.
Got excellent results (according to my taste and my goal), both B&W and coloured
here the outcomes (source image -cropped- from Deviant Art)
PostPosted: Fri Mar 13, 2015 4:13 pm  (#8)
Nice idea Lyle indeed, the halftone makes it look great too :
This filter is awesome, you can get so much different types of interesting rendering based on it !
EDIT : Another example, with the same image:
PostPosted: Fri Mar 13, 2015 5:20 pm  (#9)
A last experiment before the night :)
Please take some time to play with this new filter, it is really funny !
PostPosted: Fri Mar 13, 2015 6:44 pm  (#10)
Yeah; blending can be more an art then science David. Thought I would try a half-tone blend. :)
ref: http://www.fontplay.com/freephotos/imag ... to-642.jpg
PostPosted: Sat Mar 14, 2015 3:48 am  (#11)
PostPosted: Sat Mar 14, 2015 4:02 am  (#12)
Not yet moved to portraits, still engraving flora - corymbia ficifolia baby orange ... just a hint of colour.
PostPosted: Sat Mar 14, 2015 4:44 am  (#13)
a request (or suggestion) to David:
if possible, could you update the filter in such a way that it behaves consistently -i.e.independently from the image size-?
I show here the outcomes coming from applying your filter:
a) on the original image size
b) on the same image with reduced size
a)
b)
thanks!
PostPosted: Sat Mar 14, 2015 4:55 am  (#14)
Moved on from flora to fish sculptures this time for a bit of fun with engraving ...
PostPosted: Sat Mar 14, 2015 4:58 am  (#15)
no stopping you OMG. Love them. Thanks for the filter Lyle and David.
PostPosted: Sat Mar 14, 2015 5:06 am  (#16)
Fantastic tries above! I like this filter your David "engrave" is really good. Also I like Lyle's Style applied on the photos. Thank you for so nice results shared. :) :tyspin
Here my tries, too
PostPosted: Sat Mar 14, 2015 5:07 am  (#17)
A few more..
nazgul_on_horse_by_machimshin-d4wgs2l-Engrave+grain extract.jpg [ 135.54 KiB | Viewed 1970 times ]
PostPosted: Sat Mar 14, 2015 5:09 am  (#18)
Even more
rostros-de-mujeres-famosas-pintura-oleo-Engrave+Grain Merge.jpg [ 607.4 KiB | Viewed 1970 times ]
PostPosted: Sat Mar 14, 2015 5:40 am  (#19)
@dinasset : the filter behaves very locally, so it is already independent of the image size. On the contrary, it is dependent on the image resolution.
For a filter that does all its computations locally, this is natural (see e.g. all 'Smooth [...]' filters in the 'Repair/' section, they behaves the same).
Making this filter independent on the image resolution is an almost impossible task
(and even if I'd succeed, Im sure I'll get some request to make it independent on the image resolution :) ).
PostPosted: Sat Mar 14, 2015 5:56 am  (#20)
Sorry, David, I don't understand your answer.
The original image has been ONLY rescaled using Gimp; BOTH images (the original and the rescaled down) show -under IMAGE PROPERTIES- that they have the same resolution: 300*300.
Hence, which is the resolution you are talking about?
