It is currently Fri Nov 20, 2026 7:47 am
 Post subject: When life gives you lemons... image.
PostPosted: Tue Mar 24, 2015 3:47 pm  (#1)
Something I made with GIMP for my blog post this morning :).
I used layer masks, the artistic->cartoon script, gradients, and some other techniques I've learned from the tutorials I've done here to combine a picture of a sliced lemon with a vector image of a glass (had a lemon outline and straw to begin with).
Margaret McGaffey Fisk
steampunk, fantasy, science fiction, and romance author
Tales to Tide You Over
 Post subject: Re: When life gives you lemons... image.
PostPosted: Tue Mar 24, 2015 4:01 pm  (#2)
I like it Margaret; especially the gradient transitions. :)
PostPosted: Tue Mar 24, 2015 4:25 pm  (#3)
Thanks :). Transparency is my friend.
PostPosted: Tue Mar 24, 2015 5:16 pm  (#4)
Hi MarFisk, I think I get part of it. You don't want to make the image too appealing because it would go against your message. Does the dark black glass symbolize things not going well with your life? anyway well done
PostPosted: Tue Mar 24, 2015 7:02 pm  (#5)
You give me much too much credit. I'm a talented hack but rarely attempt any true message in my art. I leave that for my writing.
In this case, I needed an image to go with this blog post: http://margaretmcgaffeyfisk.com/finding-appreciation-in-the-midst-of-disaster/. The gist of it is I did something stupid and deleted a category on my blog by accident, but in recovering the category, discovered some older posts that still resonate with me.
Hmm, that's not far off your interpretation...
PostPosted: Tue Mar 24, 2015 8:07 pm  (#6)
Hi MarFisk, Thanks for reply ,making lemonade is suppose to be the positive part. finding the older posts was good. Sorry I read to much into your image. Some times I get carried away
PostPosted: Wed Mar 25, 2015 1:41 am  (#7)
Oh, don't be sorry :). I found your analysis fascinating, and it turned out to even have some truth within it. I've always been of the mind that while you might not have seen it when you wrote/created the work doesn't necessarily mean it wasn't subconscious.
All I was saying was it wasn't a conscious attempt to instill meaning.
PostPosted: Wed Mar 25, 2015 1:44 am  (#8)
I like your design, Margret. It fits nicely with your blog post.
PostPosted: Wed Mar 25, 2015 2:00 am  (#9)
