It is currently Fri Nov 20, 2026 6:24 am
 Post subject: Mobius-Strip Challenge
PostPosted: Wed Apr 08, 2015 8:26 pm  (#1)
I had a heck of a time making this image.
Anyone willing to take on this challenge, to create their version of this image?
 Post subject: Re: Mobius-Strip Challenge
PostPosted: Wed Apr 08, 2015 9:56 pm  (#2)
Hi Wallace - does this count? Thought I would try a different loop.
PostPosted: Wed Apr 08, 2015 11:18 pm  (#3)
Sure it counts, I can't see why it wouldn't. :bigthup
PostPosted: Thu Apr 09, 2015 12:17 am  (#4)
That looks like a pain in the neck. But very effective.
PostPosted: Thu Apr 09, 2015 2:16 am  (#5)
Hi,
Here is mine.
Cheers.
PostPosted: Thu Apr 09, 2015 2:30 am  (#6)
josephbupe wrote:
Hi,
Here is mine.
Cheers.
:jumpclap
PostPosted: Thu Apr 09, 2015 5:28 am  (#7)
And now, the Mobius-Strip.
It was a tricky one, especially that there is no way to rotate paths. So, I did stroke-path and then rotate the stroked lines. Unfortunately, that did not give smooth lines as seen in my image.
Cheers !
Joseph
PostPosted: Thu Apr 09, 2015 5:49 am  (#8)
Hi Josephbupe - just thought I would assist, because my original mobius strip above was actually generated by rotating the initial path, twice in fact. If you display the path, enter the rotate function then select the third mode option (i.e the path symbol), then you can rotate the path and of course also subsequently move it into the desired position.
Cheers and happy Gimping ;)
PostPosted: Thu Apr 09, 2015 6:05 am  (#9)
Je...sus ! Thanx for the tip.
:gimp
PostPosted: Thu Apr 09, 2015 6:31 am  (#10)
this is what I made of it
PostPosted: Thu Apr 09, 2015 3:24 pm  (#11)
Of course I had to go photographic with it:
And the G'MIC>>Deformations>>Random has a nice look to it:
Kevin
PostPosted: Thu Apr 09, 2015 4:00 pm  (#12)
Nice work you guys. :bigthup
Here as some examples I recently made.
Doing these images is great path work exercise/practice.
I encourage anyone having difficulty using the path tool to try this out.
PostPosted: Thu Apr 09, 2015 7:02 pm  (#13)
I'll bet you mean me huh? :oops: :oops: :oops:
PostPosted: Thu Apr 09, 2015 7:14 pm  (#14)
I didn't really have you in mind when I wrote that, but if you're having issues when using the path tool, then yes this challenge is especially for you.
