It is currently Fri Nov 20, 2026 5:03 am
 Post subject: Another Chihuly inspired sculpture.
PostPosted: Fri May 29, 2015 2:42 pm  (#1)
Never gets old to me. Though I had a lot of help from Flame Painter, if it wasn't for GIMP/G'MIC, this one couldn't be created. :)
https://www.flickr.com/photos/34520999@N05/18237811702/sizes/o/
 Post subject: Re: Another Chihuly inspired sculpture.
PostPosted: Fri May 29, 2015 3:34 pm  (#2)
Nice one Lyle. :bigthup
PostPosted: Fri May 29, 2015 6:17 pm  (#3)
Thanks Odin; think I got the perspective binge under control now. lol
PostPosted: Fri May 29, 2015 8:05 pm  (#4)
Wow that is really neat! mini tut please
PostPosted: Fri May 29, 2015 8:15 pm  (#5)
intricating!
PostPosted: Fri May 29, 2015 8:55 pm  (#6)
Only outlining what I used. I used a custom setting that I actually figured out how to share at Flame Painter's site; it's called Broad Sweep (notice the large L; lol). I create a wiggly looking whatever and then open it in GIMP where I use the Copy/Rotate Scriptfu and then I use some G'MIC presets (Local Orientation and Anisotropic Smoothing presets) and Graechan's Plastic or Glass Script-fu. Thanks for the comments. Gotta take the spaghetti out of the pot and cook some red gravy now. :)
edit:
Forgot to add, for this particular scupture, that I ran Mathmap Simple Droste preset to fill in the center. :)
PostPosted: Sat May 30, 2015 2:50 am  (#7)
lyle: oooooh, that's beautiful!!! you're a wizard with filters, you really are. and hey, you got out of that perspective bog too :hehe
if you make any more chihuly-influenced flowers and things, would you consider sharing some of them as brushes for less filter-skilled gimpers without access to flame painter and mathmap? *puppy dog eyes, batting eyelashes and grovelling*
PostPosted: Sat May 30, 2015 10:36 am  (#8)
Not sure these would make good brushes AnMal, but easy enough to create these with Flame Painter. Shared this one as a response from an parallel thread that I shared the above render. :)
PostPosted: Sat May 30, 2015 6:45 pm  (#9)
Lylejk
how were the spaghetti yesterday night? did you cook " al dente "?
I copied your Broad_sweep and that is all.....you are too complicate for me!!!!
Here my result! :mrgreen: :gaah
instead this is a fractal in Chaoscope
PostPosted: Sat May 30, 2015 7:20 pm  (#10)
Assume you understand that the PNG files at the repository are the presets; not sure how Peter (Flame Painter) embeds the brush information in the PNG file, but all you have to do is add it to the repository and it will show up as a brush. Anyway, all you have to do then is paint with it. As for making the output look like glass, that takes more GIMPy enhancements (that includes G'MIC). :)
PostPosted: Sun May 31, 2015 1:11 pm  (#11)
...Forgot to add, for this particular scupture, that I ran Mathmap Simple Droste preset to fill in the center. :)
PostPosted: Sun May 31, 2015 7:35 pm  (#12)
Well I use the free Flame Painter on line only so I cannot use the brushes...but I have to buy it in short!
PostPosted: Sun May 31, 2015 7:38 pm  (#13)
It literally took me 3 years to break down and purchase the original FP Marcello and then I purchased the new version. lol
PostPosted: Mon Jun 01, 2015 9:53 am  (#14)
look my scribble in FP!!!!
PostPosted: Mon Jun 01, 2015 10:24 am  (#15)
Better then mine Marcello. Just don't have hand/eye coordination with my brain when it comes to doodling. lol
Thank God for filters. :)
