It is currently Fri Nov 20, 2026 5:03 am
 Post subject: My logos thread
PostPosted: Fri Jul 03, 2015 3:20 pm  (#1)
I'm starting a separate thread for my logo's created with Gimp, as it's a separate subject. Logo creation isn't my forte, but it's something I want to get into.
Starting with the famous Batman the Movie (1989) logo. Created all from scratch. This isn't 100% accurate, but as close as I could get it.
Stage 1:
I started with several layers, and created the black border and batman logo shape with the paths tool.
Stage 2:
I then bucket filled it with black.
Stage 3:
From there I moved onto manual labouring, continuing to add more layers.
Leading up to:
Final Image:
My tools of choice: Paths tool, air brush, fill tool. I avoided gradients at all cost, even though it may not appear so.
The final image is just a screen-cap and does not represent the size of the actual logo.
Time circa 2 - 3 hours.
 Post subject: Re: My logos thread
PostPosted: Fri Jul 03, 2015 3:24 pm  (#2)
Nice one David-C. :bigthup
PostPosted: Fri Jul 03, 2015 10:25 pm  (#3)
Nice looking logo!
Have a look at the batman Logo I made using the bevel-reflect-logo script. viewtopic.php?f=11&t=11535&start=0&hilit=batman
PostPosted: Sat Jul 04, 2015 10:41 am  (#4)
Nice looking logo!
Have a look at the batman Logo I made using the bevel-reflect-logo script. http://gimpchat.com/viewtopic.php?f=11& ... lit=batman
Good one. I couldn't get the script to work though.
Here's a not-so-good attempt at making the logo 3D manually with G'mic, airbrushing and filters. Gave it a bit of a bevelled effect:
PostPosted: Sat Jul 04, 2015 11:17 am  (#5)
David-C wrote:
Nice looking logo!
That looks pretty good for doing it manually. :bigthup
I'm not sure, but did you installed the ML Bevel Reflect Plug-in, which is required for the Bevel Reflect Logo script to function properly
BTW... I have no idea what the ML in the ML Bevel Reflect Plug-in stands for.
PostPosted: Sat Jul 04, 2015 1:53 pm  (#6)
ML are the initials of the original author:
Copyright (C) 2013, Marcel Lancelle,  gimp <at> marcel-lancelle.de
See his website: http://www.marcel-lancelle.de/
Just noticed this doc on his site: http://www.marcel-lancelle.de/research/ ... ending.pdf
which addresses pretty much what tuone was asking for in this thread: viewtopic.php?f=9&t=12752
PostPosted: Sat Jul 04, 2015 10:31 pm  (#7)
Thanks Jontait2. :bigthup Thanks for the links as well.
The Marcel Lancelle documentation on Soft Edge and Soft Corner Blending is very much on the technical side. Although I do understand it, others my not.
It does however demonstrate how and why this occurs and how to avoid it or minimize it's effect.
PostPosted: Sat Jul 18, 2015 5:38 pm  (#8)
Batman Returns logo replica created from scratch (other than using the base of the original) with Gimp Painter 2.8. A combination of using shape tools, pen tools, and Mypaint brushes:
PostPosted: Mon Jul 20, 2015 6:17 pm  (#9)
My fictional Batman Forever logo. How it might have been if Tim Burton directed the third film, with the original actors and continuity present.
