It is currently Thu Nov 19, 2026 9:22 am
 Post subject: my latest sig
PostPosted: Sun Mar 13, 2011 4:13 pm  (#1)
Imageok see how the pic is blurry how do i make it unblurry . is cause when i resize it using the scale tool makes my pic blurry how do i fix that problem
 Post subject: Re: my latest sig
PostPosted: Sun Mar 13, 2011 4:20 pm  (#2)
You need to resize in Proportion mate :D, that is your problem, so if you increase one Size by 20% increase other By 20%... and it is always better to start with something huge and Make smaller (in proportion again), as then there is no quality lost. Making something bigger is much much harder, and can never be perfect.
Willy
I'm back I think
PostPosted: Sun Mar 13, 2011 10:23 pm  (#3)
Looks pretty good. When did you start making art in GIMP?
The render on the left looks a little squashed though.
Come on people make some sigs for sig of the week!
PostPosted: Sun Mar 13, 2011 10:28 pm  (#4)
lol
PostPosted: Mon Mar 14, 2011 3:31 pm  (#5)
Try Filters/Enhance/Sharpen
Be careful on the amount though - you can go overboard if you are not careful.
PostPosted: Mon Mar 14, 2011 5:38 pm  (#6)
ok thank u
