It is currently Fri Nov 20, 2026 3:36 am
 Post subject: 15 minute sketch: Plants
PostPosted: Thu Nov 19, 2015 1:24 pm  (#1)
Hi folks, been busy. Did a 15-minute speedpaint on my phone, with the the theme "plants", about as much time I have to spend at the moment.
Griatch
 Post subject: Re: 15 minute sketch: Plants
PostPosted: Thu Nov 19, 2015 2:01 pm  (#2)
Welcome back Griatch, we have missed you; pretty sketch and seasonal too!
PostPosted: Thu Nov 19, 2015 2:07 pm  (#3)
Welcome back, Griatch!
Nice to look again at your masterpieces.
(as usual, I played with your "creation": quantized and applied Bevel Reflect)
plants_speed_paint_15_mins_by_griatch_art-d9h7lc5-BRL12.jpg [ 146.57 KiB | Viewed 3147 times ]
PostPosted: Thu Nov 19, 2015 2:26 pm  (#4)
:kpix
PostPosted: Thu Nov 19, 2015 4:28 pm  (#5)
I like your creation Griatch. Nice you are come back. :) :bigthup
PostPosted: Fri Nov 20, 2015 2:45 pm  (#6)
Thanks for the kind comments. :)
@dinasset:
Nifty! I like how the sky came out all quantized. :)
Griatch
PostPosted: Fri Nov 20, 2015 4:15 pm  (#7)
Wow, nicely done, especially for just 15 minutes work Griatch. The snow/frost works really well too. Do you have pressure sensitivity on your phone?
PostPosted: Fri Nov 20, 2015 10:15 pm  (#8)
How in the world do you get such fine lines with your phone, do you have a sharp pointed stylus???
PostPosted: Fri Nov 20, 2015 11:10 pm  (#9)
Always a good picture from you Griatch :) I'm thinking the plants are probably in snow?
We have some that grow in sand as well so could do for both Winter and Summer :bigthup
PostPosted: Sat Nov 21, 2015 11:07 am  (#10)
Thats a good question 2-ton. I would like the answer to that one too. That picture is amazing
PostPosted: Sat Nov 21, 2015 6:03 pm  (#11)
Thanks, yes that's supposed to be vegetation partially covered by snow.
Yes indeed, I have a Samsung Galaxy Note 4, which I got specifically because it comes with an in-build Wacom pen (called an S-pen on the phone but it's really a Wacom device, which means no pen battery is needed). It has 2048 levels of pressure. The programs on Android don't offer quite the resources as GIMP/Krita/MyPaint but it's nice for painting on the road.
Griatch
PostPosted: Sat Nov 21, 2015 9:32 pm  (#12)
I wonder if such a stylus exists for an iPhone.
PostPosted: Sat Nov 21, 2015 9:59 pm  (#13)
I have one and it appears to me that the screen is also special made for the pen. When touching the pen to the screen in the dark, you can see a slight arc.
PostPosted: Sun Nov 22, 2015 7:48 am  (#14)
Iphones have no pressure sensitivite screens and thus you can't get a true battery-less Wacom device for it (since Wacom tech requires pen and screen to cooperate). But I think there are separate battery-driven bluetooth pens you can get, mimicking pressure sensitivity through pressing down the pen itself. I don't use Apple stuff though, so I don't know what's available.
Griatch
PostPosted: Sun Nov 22, 2015 8:51 pm  (#15)
I think either the 6s or the upcoming i phone7 is supposed to have a pressure sensitive screen. But then, apps will have to be made to use that function for art.
