It is currently Fri Nov 20, 2026 3:31 am
 Post subject: The ties that bind
PostPosted: Wed Nov 25, 2015 11:03 am  (#1)
It is not all that often that I do a series of images that are all 'connected' via a common thread.
This set of three though was done with a lovely young dancer who I felt would bring some feeling and emotion to them.
They are a bit dark, that is the intention, and I will try give a rough run down of the processing applied to each.
"The Controller" aka The ties that bind.
It was a very easy photo to take, the threads are real. The ground below her was stretched a bit, and the threads lengthened.
G'mic and the Vine brush helped create the 'flyaway' bits at the bottom of her dress, and a couple of vignetted stock images were used to create the background look and feel which would be common to all the images in the series.
"Control Lost"
Again a very simple image to shoot, and again the ground below her was stretched, and her dress lengthened to cover her shoes. Slightly different flyaway technique (Because i really don't know what I'm doing)
"Controlled"
This image was tougher to set up, and photograph, and the editing a bit different. Most the work was in cleaning up the threads piercing her back, and making fairly realistic skin "pulls"
I think they came out ok, not perfect, but pretty much what I had in mind. :)
 Post subject: Re: The ties that bind
PostPosted: Wed Nov 25, 2015 11:07 am  (#2)
Wow, they are beautiful.
PostPosted: Wed Nov 25, 2015 9:41 pm  (#3)
Very realistic, albiet a bit creepy.
cron
